1. Re: CONVERT RAW FILES FROM 5D MIII
ssprengel Apr 18, 2012 7:40 PM (in response to bradenphotography)1 person found this helpfulLR 4.1 RC and CS5 with ACR 6.7 RC or any recent version of PS/ACR or LR after converting the CR2s to DNG with DNG Converter 6.7 RC, all available from http://labs.adobe.com/
2. Re: CONVERT RAW FILES FROM 5D MIII
Curt Y Apr 18, 2012 8:07 PM (in response to bradenphotography)I don't even see it listed on the camera sheet. http://helpx.adobe.com/creative-suite/kb/camera-raw-plug-supported-cameras.html
So may be awhile. DNG for temp. fix?
3. Re: CONVERT RAW FILES FROM 5D MIII
Pattie FApr 18, 2012 8:41 PM (in response to bradenphotography)
1 person found this helpfulCamera support in Photoshop CS6, Lightroom, and ACR can be confusing.
See this link for an explanation:
http://blogs.adobe.com/lightroomjournal/2012/03/raw-support-in-lightro om-and-camera-raw.html
ACR7.1 will have the superset of all currently supported cameras in ACR6.7 and LR4.1 plus a few extras.
4. Re: CONVERT RAW FILES FROM 5D MIII
ac-photo Apr 18, 2012 10:57 PM (in response to ssprengel)DNG Converter 6.7.0.319 don't convert CR2 files from 5D MkIII. Doesn't even find them, and does nothing.
LR 4.1 works, yes.
Waiting ACR 7.1 instead.
5. Re: CONVERT RAW FILES FROM 5D MIII
ssprengel Apr 19, 2012 5:23 AM (in response to ac-photo)User error: The DNGC only converts an entire folder at a time, so you won’t see the individual files listed when you navigate to the folder containing them since the OS-dialog is only showing folders, not files.
6. Re: CONVERT RAW FILES FROM 5D MIII
ac-photo Apr 19, 2012 6:01 AM (in response to ssprengel)True ssprengel, it sees my folder with CR2 inside, but as I said, no user error, it doesn't convert.
7. Re: CONVERT RAW FILES FROM 5D MIII
ssprengel Apr 19, 2012 6:27 AM (in response to ac-photo)Ok, an unknown user error, then. The DNG Convert 6.7 RC does convert Canon 5D Mark III CR2s to DNGs. Perhaps you’re using an older version of the DNGC? Do you get an error? Do you have permissions to the folder?
8. Re: CONVERT RAW FILES FROM 5D MIII
ac-photo Apr 19, 2012 6:37 AM (in response to ssprengel)Please don't insist ! I don't come here to be accused, or insulted.
I have told that the version used was the 6.7.0.319.
I can use a computer. Yes !
I wont ask help here anymore.
11. Re: CONVERT RAW FILES FROM 5D MIII
ssprengel Apr 19, 2012 8:47 AM (in response to ac-photo)You assert the DNG Converter does not convert Canon 5D Mark III files. This assertion is false. The question is not whether you know how to use a computer, it is whether you know how to use the DNG Converter. If this is your first time, it is confusing in that it does not show you any files when you browse for the folder to convert files from. This is still the most likely explanation of your situation based on what you’ve said.
Here is a screenshot of a conversion of a 5D Mark III image with the DNG Convert 6.7 RC using a RAW image downloaded from the following website:
http://www.metrodcphotography.com/review/canon-5d-mark-iii-raw-sample-images-low-is/
12. Re: CONVERT RAW FILES FROM 5D MIII
pierresportraitart Apr 24, 2012 3:48 AM (in response to ac-photo)Digitline, I don't see anyone accusing you of anything, being rude or insulting in their response to your assertions. I understand that it is not working for you, HOWEVER, it should be so there must be another issue. There are not a lot of choices other than computer error, file error, software error, or user error. Everyone is simply trying to figure which of these it is.
13. Re: CONVERT RAW FILES FROM 5D MIII
PECourtejoie Apr 24, 2012 7:54 AM (in response to ac-photo)Hello, digitline, did you upgrade the firmware of your Mark III?
