14 Replies Latest reply on May 3, 2012 10:55 PM by Apoorva Arora
    FMS on linux
    legendarysnake Level 1
      hello,
      i recently installed FMS on my centos, but actually i am having difficult to start the server.
      #Fields: date   time    x-pid   x-status        x-ctx   x-comment
      2012-04-18      18:58:25        2513    (i)2581173      FMS detected IPv6 protocol stack!       -
      2012-04-18      18:58:25        2513    (i)2581173      FMS config <NetworkingIPv6 enable=false>        -
      2012-04-18      18:58:25        2513    (i)2581173      FMS running in IPv4 protocol stack mode!        -
      2012-04-18      18:58:25        2513    (i)2581173      Host: PTY11222C.FortaTrust.com IPv4: 127.0.0.1  -
      2012-04-18      18:58:25        2513    (e)2631013      Failed to create listener for adaptor _defaultRoot_, IP localhost, port 19350: TCCommBridge::createListener 0.0.0.0:65535/other: create socket failed.. -
      2012-04-18      18:58:25        2513    (e)2631013      Failed to create listener for adaptor _defaultRoot_, IP , port 80: TCCommBridge::createListener 0.0.0.0:80/v4: bind failed!!!.  -
      2012-04-18      18:58:25        2513    (e)2631114      Failed to start listeners for adaptor _defaultRoot__edge1.      -
      2012-04-18      18:58:25        2513    (e)2791225      Failed to start edge : _defaultRoot__edge1      -
        • 1. Re: FMS on linux
          Shiraz Anwar Adobe Employee
          Your sockets seems to be occupied, please shut down any other service that must be using these ports.
          • 2. Re: FMS on linux
            Luis Sanchez Tapia Level 1
            Execute "netstat -nl" to see what port are accupied or are user for a service.
            • 3. Re: FMS on linux
              ctive Internet connections (only servers)
              Proto Recv-Q Send-Q Local Address               Foreign Address             Stat        e
              tcp        0      0 0.0.0.0:3306                0.0.0.0:*                   LIST        EN
              tcp        0      0 0.0.0.0:111                 0.0.0.0:*                   LIST        EN
              tcp        0      0 0.0.0.0:10000               0.0.0.0:*                   LIST        EN
              tcp        0      0 0.0.0.0:22                  0.0.0.0:*                   LIST        EN
              tcp        0      0 127.0.0.1:631               0.0.0.0:*                   LIST        EN
              tcp        0      0 127.0.0.1:25                0.0.0.0:*                   LIST        EN
              tcp        0      0 0.0.0.0:989                 0.0.0.0:*                   LIST        EN
              tcp        0      0 :::80                       :::*                        LIST        EN
              tcp        0      0 :::22                       :::*                        LIST        EN
              tcp        0      0 ::1:631                     :::*                        LIST        EN
              udp        0      0 0.0.0.0:10000               0.0.0.0:*
              udp        0      0 0.0.0.0:44102               0.0.0.0:*
              udp        0      0 0.0.0.0:983                 0.0.0.0:*
              udp        0      0 0.0.0.0:986                 0.0.0.0:*
              udp        0      0 0.0.0.0:5353                0.0.0.0:*
              udp        0      0 0.0.0.0:111                 0.0.0.0:*
              udp        0      0 0.0.0.0:631                 0.0.0.0:*
              udp        0      0 :::5353                     :::*
              udp        0      0 :::33517                    :::*
              Active UNIX domain sockets (only servers)
              Proto RefCnt Flags       Type       State         I-Node Path
              unix  2      [ ACC ]     STREAM     LISTENING     6357   /var/run/cups/cups.sock
              unix  2      [ ACC ]     STREAM     LISTENING     5975   /var/run/sdp
              unix  2      [ ACC ]     STREAM     LISTENING     5897   /var/run/dbus/system_bu        s_socket
              unix  2      [ ACC ]     STREAM     LISTENING     4875   @ISCSIADM_ABSTRACT_NAME        SPACE
              unix  2      [ ACC ]     STREAM     LISTENING     6074   /var/run/pcscd.comm
              unix  2      [ ACC ]     STREAM     LISTENING     6107   /var/run/acpid.socket
              unix  2      [ ACC ]     STREAM     LISTENING     8267   @/tmp/fam-root-
              unix  2      [ ACC ]     STREAM     LISTENING     6995   @/var/run/hald/dbus-npD        xcfuB7D
              unix  2      [ ACC ]     STREAM     LISTENING     100330 /var/lib/mysql/mysql.so        ck
              unix  2      [ ACC ]     STREAM     LISTENING     4858   @ISCSID_UIP_ABSTRACT_NA        MESPACE
              unix  2      [ ACC ]     STREAM     LISTENING     6996   @/var/run/hald/dbus-m3x        H5OA4cR
              unix  2      [ ACC ]     STREAM     LISTENING     6949   /var/run/avahi-daemon/s        ocket
              unix  2      [ ACC ]     STREAM     LISTENING     6815   /dev/gpmctl
              unix  2      [ ACC ]     STREAM     LISTENING     5303   /var/run/audispd_events
              • 4. Re: FMS on linux
                Port 80 is used, probably by apache.
                • 5. Re: FMS on linux
                  i stopped the apache, and i still unable to run the fms.
                  can someone login on my system on ssh, and help me?
                  • 6. Re: FMS on linux
                    i changed the port, reinstalled the server, and nothing, return error to bind on port 19350
                    • 7. Re: FMS on linux
                      Make sure that ICMP 19350 port is open.
                      It will be better if you can open all the ICMP port, but if there are security threats, you may need to open 19350 and 11110 ICMP porrts atleast as they are used for internal communication among processes.
                      Regards,
                      Shiraz Anwar
                      • 8. Re: FMS on linux
                        can you login on my shell?
                        • 9. Re: FMS on linux
                          I didnt see your messge earlier and am back to my home for weekend, I had opened the shell for few minutes and saw the edge crashing in your logs, installation is looking fine to me. Only thing that I still need to verify is the conf folder. Couldnt spend much time on this, wil lrevert back to you around Monday on this issue, meantime am not sure if you have already tried this tutorial - http://help.adobe.com/en_US/flashmediaserver/configadmin/WSdb9a8c2ed4c02d261d76cb3412a40a4 90be-8000.html
                          See and let me know if it works for you.
                          • 10. Re: FMS on linux
                            wont work, can someone help me?
                            • 11. Re: FMS on linux
                              Apoorva Arora Level 2
                              Have you verified if your system's firewall is off ?
                              You can check the status of your firewall by running this command in your shell - service iptables status. Sometimes it happens that your firewall won't allow FMS to listen on ports 1935 and 80, because of which
                              FMS fails to start.
                              If the firewall is up, please try switching it off and restart your server again. Command to stop firewall is - service iptables stop.
                              • 12. Re: FMS on linux
                                the ports 1935 and 80 is accepted on firewall, can you login on my system and try?
                                • 13. Re: FMS on linux
                                  i stopped the fierewall, still not working.
                                  • 14. Re: FMS on linux
                                    Here are a few things I would like you to run -
                                    1. Tell me which version of FMS you are trying to install.
                                    2. Execute 'ps -elaf | grep fms'  on your shell and let me know the result. I am just trying to make sure there are no multiple instances installed on your server machine that may be causing any problems
                                    3. Uninstall the FMS server.
                                    4. Check again for running processes by executing 'ps -elaf | grep fms'
                                    5. Now run 'netstat -tulpn | grep :80' and 'netstat -tulpn | grep :1935' to check if any of these ports are being used by FMS or some other process.
                                    6. If you find any process that is currently using any of the two ports, please kill them.
                                    7. Please make sure you have your firewall disabled and no other security policy in place that may be blocking FMS from using the ports. Once we have FMS running, we can sort out the problem and enable security policies again as suitable for your requirements.
                                    8. Now install your server again. While installation, ensure that the installer is not throwing any errors or warnings.
                                    I know you may have done all this but just to be sure it would be great if you follow the steps in order, so that we finally catch and solve your issue. Let me know how it goes.
                                    Regards.
