2 Replies Latest reply on Apr 20, 2012 6:15 AM by jblairdynis
    autocad 2010 drawing pasted in microsoft excel 2007 spread sheet not visible after converting excel
    jblairdynis
      Hello, I am having an issue with Autocad 2010 drawings not showing up in a pdf document. Normally, I cut and paste part of an Autocad 2010 drawing into a Microsoft Excel 2007 spread sheet. Then, using Adobe Distiller, I convert the Excel spread sheet into a pdf document for propriatary purposes. However, recently the drawing pasted into Excel will not fully appear on the pdf, the drawing is cut off past a certain point. The drawing will print normally in Excel, but in pdf will not print normally. If the drawing is shrunk below the "cut off" point, it appears normally. If the drawing is expanded above the "cut off" point, any additional image is lost. Any suggestions on how to fix the problem would be appreciated.
