3 Replies Latest reply on Apr 19, 2012 1:41 PM by Harbs.
    variables in regexp
    scriptworker
      Hello,
      Is there a way to use variables in regular expressions?
      Can't find the right syntax.
      var pattern = RegExp('/\n\d\t[^\t]+\t\d\t/' + var);
      This does not work.
      Michel
        • 1. Re: variables in regexp
          Marc Autret Level 4
          Hi Michel,
          By 'variable' you mean any expression which can be coerced into a String, right? The point is to clearly make a distinction between a regex pattern (which is a string) and the RegExp instance itself:
          var myString = "Hello";
          var myPattern = "\\n\\d\\t[^\\t]+\\t\\d\\t" + myString;
          var myRegex = new RegExp(myPattern, 'g');
          // myRegex is then equivalent to: /\n\d\t[^\t]+\t\d\tHello/g
          Note that all regular expression metacharacters such as \n or \d must be double-escaped when you introduce them through a literal string (cf. myPattern declaration).
          Marc
          • 2. Re: variables in regexp
            John Hawkinson Level 5
            I would write Marc's example using this horrible construct:
            var myPattern = /\n\d\t[^\t]+\t\d\t/.source + myString;
            because it avoids the double-quoting.
            • 3. Re: variables in regexp
              Harbs. Level 6
              John Hawkinson wrote:
              ...using this horrible construct:
              Nice! I don't think I've seen that one before.
              Harbs
