1. Re: Looking for some Flash tutorials
Ned Murphy Apr 20, 2012 4:59 AM (in response to mentalcase129)Your best bet for finding tutorials is to search Google using terms specific to you needs. Try using "AS3 gallery tutorial" and "AS3 custom scrollbar tutorial"
2. Re: Looking for some Flash tutorials
mentalcase129 Apr 24, 2012 9:02 PM (in response to Ned Murphy)I've been googling like a mad man. Managed to find some help with the gallery but not having a lot of luck with the scroll bar. I've found some from older versions of flash that seem to be just different enough to confuse me when I try to do them in cs5.5 lol. Can anybody give me any advice on scrollbars? I'm having trouble even getting the preset scrollbar in the components to work properly which I imagine is supposed to be pretty simple.
thanks
3. Re: Looking for some Flash tutorials
bhargavi reddy Apr 25, 2012 2:27 AM (in response to mentalcase129)http://theflashconnection.com/book/export/html/186 go through this link you can find vertical custom scroll bar making.
4. Re: Looking for some Flash tutorials
mentalcase129 Apr 27, 2012 10:53 AM (in response to bhargavi reddy)I can take a stab at that tutorial from Flash connection but if anyone has advice a REALLY simple tutorial or even advice on how to make one themselves that'd be great. I went through this tutorial yesterday: http://www.schoolofflash.com/2011/05/smooth-scrollbar-flash-tutorial/
It seems really simple and straight forward and I'm still getting errors from it and can't figure out what I'm doing wrong...kinda banging my head agains the wall at this point.
5. Re: Looking for some Flash tutorials
mentalcase129 Apr 27, 2012 11:18 AM (in response to mentalcase129)I just thought of something. That tutorial I mentioned in the above post...I've followed everything exactly as far as I can tell...I solve a couple problems along the way and no longer get any compiler errors, but when I render to an swf the scrollbar isn't functional and I get this message in the output
TypeError: Error #1010: A term is undefined and has no properties.
at scrollbar_fla::scrollbar_46/frame1()
at flash.display::MovieClip/gotoAndPlay()
at scrollbar_fla::MainTimeline/fl_ClickToGoToAndPlayFromFrame_5()
I'm pretty new to actionscript so maybe this is pointing me to an easy fix that I'm just not recognizing...does anybody have any suggestions based on this kinda of error? The scrollbar I made is inside a movie clip that stops on frame 46...so presumably that's why the number 46 appears in the error?
6. Re: Looking for some Flash tutorials
bhargavi reddy May 2, 2012 12:00 AM (in response to mentalcase129)You can create mask for the movieclip as exactly as in your tutorial. and use below code (I think this is what you want).
For using the below code you should create some user defined components.
For Horizontal Scroll Bar: create hscrollBG for scrollbar background and hscroller for scroller.
For Vertical Scroll Bar: create vscrollBG for scrollbar background and vscroller for scroller.
mask_mc is mask movieclip and content_mc is which the content you want to scroll.
/**** code ****/
var hscrollbar:MovieClip;
var vscrollbar:MovieClip;
if (content_mc.height > mask_mc.height)
drawVScrollBar();
if(content_mc.width > mask_mc.width)
drawHScrollBar();
private function drawVScrollBar():void
try
removeChild(vscrollbar);
catch (e:Error)
vscrollbar = new MovieClip();
addChild(vscrollbar);
vscrollbar.x = mask_mc.width + 5; //set scrollbar position
var bg:vscrollBG = new vscrollBG();
bg.height = mask_mc.height;
vscrollbar.addChildAt(bg,0);var scroller:vscroller = new vscroller();
scroller.x = 1;
scroller.y = 0;
vscrollbar.addChildAt(scroller,1);
scroller.addEventListener(MouseEvent.MOUSE_UP, sc_mouseup);
scroller.addEventListener(MouseEvent.MOUSE_DOWN, sc_mousedown);
stage.addEventListener(MouseEvent.MOUSE_UP, sc_mouseup);
private function sc_mousedown(e:MouseEvent):void
var scroller:MovieClip = vscrollbar.getChildAt(1) as MovieClip;
scroller.startDrag(false, new Rectangle(1, 0, 0,mask_mc.height- scroller.height));
scroller.addEventListener(Event.ENTER_FRAME, updateScrollPosition);
private function sc_mouseup(e:MouseEvent):void
stopDrag();
scroller.removeEventListener(Event.ENTER_FRAME, updateScrollPosition);
private function updateScrollPosition(e:Event):void {
var bg:MovieClip = vscrollbar.getChildAt(0) as MovieClip;
var perc:Number = scroller.y * 100 / (bg.height-scroller.height);
var ypos:Number = ( -perc * ((content_mc.height - mask_mc.height) / 100));
content_mc.y = ypos;
private function drawHScrollBar():void
try
removeChild(hscrollbar);
catch (e:Error)
hscrollbar = new MovieClip();
addChild(hscrollbar);
hscrollbar.y = mask_mc.height + 5;
var bg:hscrollBG = new hscrollBG();
bg.width = mask_mc.width;
hscrollbar.addChildAt(bg,0);var scroller:hscroller = new hscroller();
scroller.x = 1;
scroller.y = 0;
hscrollbar.addChildAt(scroller,1);
scroller.addEventListener(MouseEvent.MOUSE_UP, hsc_mouseup);
scroller.addEventListener(MouseEvent.MOUSE_DOWN, hsc_mousedown);
stage.addEventListener(MouseEvent.MOUSE_UP, hsc_mouseup);
private function hsc_mousedown(e:MouseEvent):void
var bg:MovieClip = hscrollbar.getChildAt(0) as MovieClip;
var scroller:MovieClip = hscrollbar.getChildAt(1) as MovieClip;
scroller.startDrag(false, new Rectangle(bg.x, bg.y, bg.width - scroller.width,0));
scroller.addEventListener(Event.ENTER_FRAME, hupdateScrollPosition);
private function hsc_mouseup(e:MouseEvent):void
stopDrag();
scroller.removeEventListener(Event.ENTER_FRAME, hupdateScrollPosition);
private function hupdateScrollPosition(e:Event):void {
var perc:Number = (scroller.x - bg.x) / (bg.width - scroller.width);
var xcounter:Number = ( -perc * (content_mc.width - mask_mc.width));
content_mc.x = xcounter;
}This code is reusable for many applications where we want scrollbar. In this code we can dynamically assign the scrollbars based on the content width and height.
