1. Re: Access to workstation name
try67 Apr 20, 2012 1:20 AM (in response to FUBARinSFO)There isn't a direct way to do that, but I think it might be possible by
smartly manipulating the various results provided by app.getPath().
2. Re: Access to workstation name
FUBARinSFO Apr 20, 2012 2:31 PM (in response to try67)Maybe, but unlikely. 'path' itself is a misnomer, since it delivers both path and filename. And fails to report the drive.
It occurs to me that maybe a better approach to this whole thing is to do the pdf manipulation from Windows Scripting Host. Then at least all the file and system information will be available.
I haven't looked at LiveCycle or xfa or SOAP or other possible technologies. I understand ADBC was dropped from Adobe X. It would have provided a simple way to read or import an external file with the information of interest, that could then be added to a header/footer.
-- Roy Zider
3. Re: Access to workstation name
try67 Apr 20, 2012 2:41 PM (in response to FUBARinSFO)I'm not talking about path, which returns the full path of a file
(including the drive letter, by the way), but about app.getPath() which can
return various system- and user-level folders used by Acrobat. Many times
these contain the name of the currently logged-in user, as well as some
other information.
Maybe you can be a bit more specific about what exactly you want to get?
4. Re: Access to workstation name
GKaiseril Apr 20, 2012 2:47 PM (in response to FUBARinSFO)With Acrobat JS not the workstation ID. File paths and URL for a PDF stored on a network drive is possible:
console.println("\nthis.URL:\n" + this.URL);
console.println("\nthis.path:\n" + this.path)this.URL:
file:///H|/My%20DocumentsISR/Adobe/Console.pdfthis.path:
/ORDHOME.CHICAGO.ISRWORLDWIDE.COM/GEORGE$/My DocumentsISR/Adobe/Console.pdftrue
You could use additional Acrobat JS to extract the path or remove the file name and extension.
5. Re: Access to workstation name
FUBARinSFO Apr 20, 2012 8:33 PM (in response to try67)try67:
I'd be interested in seeing how you get the drive letter from 'this.path'. I've not been able to do it.
The function app.getPath() returns the dpath (drive-path) of various folders created during installation. I didn't see any reference in the API to any system information.
What I'm trying to do is very simple: in a footer, I want to post the workstation name of the host that's stamping the pdf. So, '[MPX2] D/My Documents/test logs.pdf' and '[K7N] D/My Documents/test logs.pdf' for workstations MPX2 and K7N, bzw.
-- Roy Zider
6. Re: Access to workstation name
try67 Apr 21, 2012 6:44 AM (in response to FUBARinSFO)this.path.substring(1,2) will return the drive letter where the current
file is located.
I don't think you can get the local name of the workstation using
app.getPath(), though. You can get the name of the current user...
7. Re: Access to workstation name
FUBARinSFO Apr 21, 2012 11:30 AM (in response to try67)try67:
You are so right. Substring not necessary (but good reminder of another method). I misread my own system.
I've got three workstations active; on one of them[MPX2] the drive assignments are simple: C: and D; on another [K7N] the directories are treed: D:\D, D:\E, D:\F, and so forth. I read /D/MyDox/<filename> as being on the K7N workstation with the 'virtual' sub-drive directory structure, when in fact I was on the other workstation (MPX2) I had lost track of which system I was woking with.
Sorry for any inconvenience, and thank you for bucking this back to me.
-- Roy Zider
