4 Replies Latest reply on Jan 2, 2013 1:40 PM by Sweeney70
    Blackberry Playbook and library books
    onecherryberry
      I cannot get the Digital Editions loaded on my PC to "see" my Playbook when it is attached so that I can download books from the library (it dos now show on the Bookshelf). PC says it is authorized.
      Thank you, Cherry
        • 1. Re: Blackberry Playbook and library books
          Frustrated in AZ Level 4
          You've been caught up in the syndrome that, just because you're supposed
          to be able to read ebooks on your device, you assume that all you have to
          do is to hook it to your PC and you're good to go.  There's some technology
          in the middle, and it's important because it makes everything work.
          ADE does not support your Blackberry.  That's not going to change soon,
          either, unfortunately.  Once you get your library ebook downloaded to your
          computer, you can't transfer it to your Blackberry.
          • 2. Re: Blackberry Playbook and library books
            Sweeney70
            The Problem is another in my opinion.
            Facts:
            - Playbook can read DRM-eBooks with Kobo.
            - Kobo Desktop is a featured device on Windows, but I can't import there my books from ADE or send them from ADE to Kobo.
            - ADE supports the playbook not native
            I have to a) remove DRM and copy it on my playbook; or b) use another Reader (Android) to read DRM-protected ebooks. This not easy-way.
            Please tell us how we can send our bought ebooks from ADE to KoboDesktop. This would be the way Adobe says.
            • 3. Re: Blackberry Playbook and library books
              No, the Blackberry is not a supported device under ADE.   Your choice of
              the term 'not native' could mean that the Blackberry is supported some
              other way by ADE, which is not true.  Thus, there is no way to connect the
              Blackberry to ADE directly.
              ADE does provide both library management and support for DRM-enabled
              epublications.  As you point out, so do other software systems.  And
              because there are other software systems that do support DRM-enabled
              publications, plus other systems interface with your Blackberry, perhaps
              you should look at those systems to use instead of ADE.
              Yes, KOBO's desktop support for epublications is independent of, and cannot
              run with, ADE.
              So, if you have alternatives, why are you asking how to interface ADE with
              the KOBO desktop?
              • 4. Re: Blackberry Playbook and library books
                Sweeney70 Level 1
                Hello again,
                I hoped to get help, but Adobe won't do it.
                My alternative is illegal and you give me advice to do it? O-(
                It's not neccessary to sync to kobo desktop, but directly to the Playbook.
                Where is the announced support of the Playbook?
                Greetings
