8 Replies Latest reply on Apr 27, 2012 2:12 AM by Jhon Carlo
    Problem with exitFrame/startTimer
    Jhon Carlo Level 1
      Why the following script does not work?
      on exitFrame me
        if member("MyText").text = "x" then
          go to the frame
        end if ---(with else is the same)
        if member("MyText").text = "y" then
           startTimer
           if the timer < 5000 then
              go next
            end if
          end if
        end if
      end
      I have tried some variations on this approach but it does not work.
      Some help?
        • 1. Re: Problem with exitFrame/startTimer
          Sean_Wilson Adobe Community Professional
          You have one too many 'end if' statements in your code.
          It's difficult to know what is happening (you don't say), especially since you give no clues as to what the text of member "MyText" contains or, more generally, what you're trying to achieve. You're obviously wanting to pause on a particular frame until the text of a member is a certain character, but how do you initialise this text member and where is the code you posted attached? For example, if the code is in the frameScript channel and member("MyText") is anything other than "x" or "y" when it runs then the playhead will breeze past this frame and onto the next one.
          • 2. Re: Problem with exitFrame/startTimer
            Jhon Carlo Level 1
            Thank you Sean for you fast reply!
            Sorry, of course, I've write more "and if" in the previous post then in my original script.
            I'm trying to stop for a while on the frame (the previous script is in a "frame Script"). My text contain only a "X" or "Y" (but il can contain "foo" or whatever). I switch form X or Y from a button, but the condition (x and y) have non effect and I miss the: "go to the frame" on the "exitFrame".
            Can you give me any hint?
            Thank you.
            • 3. Re: Problem with exitFrame/startTimer
              Production Monkey Level 3
              This may be what you are trying to do:
              on exitFrame me
                  startTimer
                  go next
                else
                  go the frame
                end if
              end exitFrame
              Another approach would be to use the exitframe handler for nothing but pausing on a frame and then take the action of going to the next frame in your button script.
              on mouseDown me
                  startTimer
                  go next
              end mouseDown
              • 4. Re: Problem with exitFrame/startTimer
                Jhon Carlo Level 1
                Thanks Production Monkey for the kind reply,
                but I need the condition: "Timer > ...." I tried your suggestions by making the following changes:
                exitFrame on me
                   if member ("Recording"). text = "stoRegistrando" then
                     startTimer
                     if the timer > 500000 then --- (I tried this with different values)
                       go next
                     end if
                   else
                     go the frame
                   end if
                end exitFrame
                But it does not work. When imposed "MyText" = "y", with the button, the movie go immediately to the next frame without aspect even a moment. I tried putting "startTimer" in the button, like you suggested, but it does not work. Why?
                Any advice?
                • 5. Re: Problem with exitFrame/startTimer
                  I did not understand that you want to use the timer to delay the jump to the next frame. I would use a timeout object to create the delay
                  Try this frame script. I assume you are using D10 or later.
                  property Paused  -- true/false flag indicating in paused state
                  on beginSprite me
                    Paused = false
                  end
                  on exitFrame me
                    if member ("Recording"). text = "stoRegistrando" AND Not Paused then
                      tmp = timeout().new("paused_"&me, 3000,  #goNext, me) -- 3000 = 3 second delay
                      Paused = true
                    end if
                    go the frame
                  end exitFrame
                  on goNext me, timeOb
                    timeOb.forget()
                    go next
                  end goNext
                  Or, like I mentioned above just pause on the frame and use a button script to go to the next marker.
                  on mouseDown me
                  end mouseDown
                    timeOb.forget()
                    go next
                  end goNext
                  • 6. Re: Problem with exitFrame/startTimer
                    Jhon Carlo Level 1
                    Thanks again Production Monkey,
                    only the mouse
                    script works, but not always!!!
                    I think there is some problem in the context. I must stop to recording a sound file when it is finished "mix.stopSave ()". I do not want to do this to the user because if doesn't stop this could continue record and to fill the HD. So I want to determine, according to the length of the track, when the recording must stop. (sound(...).isBusy()) doesn't work.
                    As mentioned above only the mouse script works but not always.
                    I tried to understand the timeOut but I must say that the help of Director is not the most clear, there are no concrete examples. So
                    thanks you also for this, now I understand the TimeOut object.
                    Any further suggestions?
                    Thank you very much.
                    • 7. Re: Problem with exitFrame/startTimer
                      You don't say what happens when the mouse script does not work.
                      I'm also confused by what you are trying to accomplish. My best guess is that you are saving a sound file and you want the save to complete before moving to another frame.
                      Timeout objects are great for monitoring/polling a condition because they will continue to call a handler at a regular interval until you forget them. The pseudo code for saving an audio file and then waiting for it to complete before moving to another frame would be:
                      on mouseDown me
                        soundObjRef.save("C:\audio.wav")
                        tmp = timeout().new("paused_"&me, 500,  #isSaveDone, me) -- 500 = 0.5 second delay
                      end mouseDown
                      on isSaveDone me, timeOb
                        if soundObjRef.isSaving()then
                          put "Still saving sound file"
                        else
                          timeOb.forget()
                          put "Done saving sound file."
                          go next
                        end if
                      end isSaveDone
                      Note:  This code is untested and will need to be modify to work.
                      • 8. Re: Problem with exitFrame/startTimer
                        Jhon Carlo Level 1
                        I apologize for answering so late, but these days I could not work on your last help. I tried it today and it works great.
                        Thanks a lot for your help.
