1 Reply Latest reply on Apr 21, 2012 4:31 AM by Ned Murphy
    i am try to figure out how to make a class, Input and output data
    rantexfire Newcomer
      When i was younger i programmed in fortran and pascal. I was ok at it. Now i am trying to learn to make games with flash. i started about threes weeks and have been reading the forums and flash help file but when i try to make my own class it either say i need a package or that the class cannot be nested. i'm sure it is some stupid little thing i need to my it work. here is my code:
      class Enemy
      // variable Declarations
      var enemyHealth:int
      var enemyName:String
      var enemyDefence:int
      var enemyAttack:int
      var enemyDead:Boolean
      // constructer
      function enemy (enemyHealth:int,enemyName:String,enemyDefence:int,enemyAttack:int,enemyDead:Boolean)
      this.enemyHealth  = enemyHealth;
      this.enemyName    = enemyName;
      this.enemyDefence = enemyDefence;
      this.enemyAttack  = enemyAttack;
      this.enemyDead    = enemyDead;
      // get function to display in textboxes
      public function getEnemyHp():int
        return enemyHealth;
      public function getEnemyName():String
        return enemyName;
      public function getEnemyDef():int
      return enemyDefence;
      public function getEnemyAtt():int
        return enemyAttack;
      public function getEnemyDead():int
        return enemyDead;
      This the only thing in the flash project, no graphics, no textboxes, nothing.
      the compiler gives this error:
      1131: Classes must not be nested.
      if any one know of a previous post (so don't have re-explain )or can explain what i need to look for in the help files i would be very thankful.
        • 1. Re: i am try to figure out how to make a class, Input and output data
          Ned Murphy Legend
          Where are you trying to place this code.  If you are making classes, then create them as separate .as files.  If you are trying to code inside the fla file, then do not use class-based syntax (class, public, etc).  If your are trying to code this as a class file it should look like...
          package {
              public class Enemy extends MovieClip {
                  var enemyHealth:int
                  var enemyAttack:int
                  // constructer
                  public function Enemy (enemyHealth:int,enemyName:String,enemyDefence:int,enemyAttack:int,en emyDead:Boolean){
                  public function getEnemyHp():int  {
                       return enemyHealth;
                  public function getEnemyName():String {
                       return enemyName;
                  public function getEnemyDef():int {
                  public function getEnemyAtt():int {
                      return enemyAttack;
                  public function getEnemyDead():int {
                      return enemyDead;
          and you need to save the file using the file name:  Enemy.as, and either store the file in the same folder as the fla file (easiest for now), or within your classpath (probably can wait to learn what/how)
