13 Replies Latest reply on Apr 27, 2012 9:10 AM by munira06
    RegExp for excluding special characters in a string.
    munira06 Level 1
      Hi All,
      Im using Flex RegExpValidator. Can anyone suggest me the correct expression to validate this condition?....
      I have tried this expression :----- /^[^///\/</>/?/*&]+$/...But in this it is also negating the alphabets.Also I have tried with opposite condition that in the String we should have alphabets and the expression is:-- ([a-z]|[A-Z]|[0-9]|[ ]|[-]|[_])*..... Please can anyone help me on this.
      Thanks in advanced to all.
      Munira
        • 2. Re: RegExp for excluding special characters in a string.
          munira06 Level 1
          Hi ,
          Thanks for your reply.I have tried this condition.
          And got following result:--
          If you give only alphabets with no special symbols.The expression is valid
          that is what is my requiremnet.
          If you give only special characters .Expression is invalid what is our
          requiremnet.
          But if you give mixed expression of Special symbols and alphanumeric
          characters it is considering it as Valid .
          iwr ote:
             Re: RegExp for excluding special characters in a string.  created by
          spoboyle <http://forums.adobe.com/people/spoboyle> in Flex - View the
          full discussion <http://forums.adobe.com/message/4354492#4354492
          • 3. Re: RegExp for excluding special characters in a string.
            _spoboyle Level 4
            did you use
            var pattern:RegExp = /^[a-zA-Z0-9 -_]*$/;
            or
            var pattern:RegExp = /^[a-zA-Z0-9 \-_]*$/;
            remember - needs to be escaped since it's used to indicate a range of values
            • 4. Re: RegExp for excluding special characters in a string.
              munira06 Level 1
              I have used these expressions ,but nothing worked properly with
              RegExpValidator:--
              ^[a-zA-Z0-9_-]$
              ^[-_,A-Za-z0-9]$
              Also I have tried with the expressions u have provided .But the same
              problem occurs it Invalidates alphanumeric characters as well.
              May be its RegExpValidator issue or some expression issue.
              What I have noticed is that the negate character (^) is not considered as
              negate.
              Please assist me to get it resolved.
              Thanks and Regards
              Munira
              • 5. Re: RegExp for excluding special characters in a string.
                _spoboyle Level 4
                ^ at the start is not a negate its a start of line character
                ^ within a [] is a negation
                • 6. Re: RegExp for excluding special characters in a string.
                  munira06 Level 1
                  Yes you are correct ,but I have tried this with single special character
                  say
                  Then also its not negating it ...
                  Can you please put some light on it.
                  Thanks and Regards
                  Munira
                  • 7. Re: RegExp for excluding special characters in a string.
                    _spoboyle Level 4
                    sorry but you are posting things back that do not make any sense
                    what do you mean with the below comment?
                    say
                    here is a sample app taken from the live docs
                    using ^[a-zA-Z0-9 \-_]*$ as the regex accepts all characters from a-z, A-Z, 0-9 - [space] and_
                    run the example tell me what regex you are using and what test strings fail when they should pass or pass when they should fail
                    <!-- Simple example to demonstrate the RegExpValidator. -->
                            xmlns:mx="library://ns.adobe.com/flex/mx">
                        <fx:Script>
                            <![CDATA[
                                import mx.events.ValidationResultEvent;
                                import mx.validators.*;
                                // Write the results to the
                                private function handleResult(eventObj:ValidationResultEvent):void {
                                    if (eventObj.type == ValidationResultEvent.VALID) {
                                        // For valid events, the results Array contains
                                        // RegExpValidationResult objects.
                                        var xResult:RegExpValidationResult;
                                        reResults.text = "";
                                        for (var i:uint = 0; i < eventObj.results.length; i++) {
                                            xResult = eventObj.results[i];
                                            reResults.text=reResults.text + xResult.matchedIndex + " " + xResult.matchedString + "\n";
                                    } else {
                        </fx:Script>
                        <fx:Declarations>
                            <mx:RegExpValidator id="regExpV"
                                    source="{regex_text}" property="text"
                                    flags="g" expression="{regex.text}"
                                    valid="handleResult(event)"
                                    invalid="handleResult(event)"
                                    trigger="{myButton}"
                                    triggerEvent="click"/>
                        </fx:Declarations>
                        <s:Panel title="RegExpValidator Example"
                                width="75%" height="75%"
                                horizontalCenter="0" verticalCenter="0">
                            <s:VGroup left="10" right="10" top="10" bottom="10">
                                <s:Label width="100%" text="Instructions:"/>
                                <s:Label width="100%" text="1. Enter text to search. By default, enter  a string containing the letters ABC in sequence followed by any digit."/>
                                <s:Label width="100%" text="2. Enter the regular expression. By default, enter ABC\d."/>
                                <s:Label width="100%" text="3. Click the Button control to trigger the validation."/>
                                <s:Label width="100%" text="4. The results show the index in the text where the matching pattern begins, and the matching pattern. "/>
                                <mx:Form>
                                    <mx:FormItem label="Enter text:">
                                        <s:TextInput id="regex_text" text="xxxxABC4xxx" width="100%"/>
                                    </mx:FormItem>
                                    <mx:FormItem label="Enter regular expression:">
                                        <s:TextInput id="regex" text="ABC\d" width="100%"/>
                                    </mx:FormItem>
                                    <mx:FormItem label="Results:">
                                        <s:TextInput id="reResults" width="100%"/>
                                    </mx:FormItem>
                                    <mx:FormItem >
                                        <s:Button id="myButton" label="Validate"/>
                                    </mx:FormItem>
                                </mx:Form>
                            </s:VGroup>
                        </s:Panel>
                    </s:Application>
                    • 8. Re: RegExp for excluding special characters in a string.
                      munira06 Level 1
                      I have tried  with your expression:--
                      But some time it shows invalid msg for special characters .
                      Not all time you give .
                      You can try with following code:--
                         xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"
                      xmlns:local="*">
                      <fx:Script>
                      <![CDATA[
                      private var exp106:String = "^[a-zA-Z0-9 \-_]*$"
                      private function button1_clickHandler(event:MouseEvent):void{
                      regValidator.validate();
                      </fx:Script>
                      <fx:Declarations>
                      <!-- Place non-visual elements (e.g., services, value objects) here -->
                      <mx:RegExpValidator id="regValidator" expression=""
                      noMatchError="Not valid" source=""
                      flags="g" property="text" required="true" requiredFieldError="Please enter
                      string" />
                      </fx:Declarations>
                      <mx:VBox>
                      <s:TextInput id="textBox" />
                      <s:Button label="validate" click="button1_clickHandler(event)" />
                      </mx:VBox>
                      </s:Application
                      • 9. Re: RegExp for excluding special characters in a string.
                        _spoboyle Level 4
                        it would be helpful if you can stop posting Re: RegExp for excluding special characters in a string. in the middle of all you posts
                        and tell me what test strings are failing when they should pass or pass when they should fail
                        • 10. Re: RegExp for excluding special characters in a string.
                          _spoboyle Level 4
                          once I had worked out how to make your code compile
                          I had to make some small change for some reason I can't get the expression to bind to exp106 but if I hard code the regex into your validator I cna't find any cases that doesn't wrk as intended.
                             xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:local="*">
                                    <fx:Script>
                                    <![CDATA[
                                              [Bindable]
                                              private var exp106:String = "^[a-zA-Z0-9 \-_]*$";
                                    </fx:Script>
                                    <fx:Declarations>
                                                        expression="^[a-zA-Z0-9 \-_]*$" source="{textBox}"
                                                        flags="g" property="text" required="true" requiredFieldError="Please enter string"/>
                                    </fx:Declarations>
                                    <mx:VBox>
                                    </mx:VBox>
                          </s:Application>
                          • 11. Re: RegExp for excluding special characters in a string.
                            munira06 Level 1
                            Hi
                            Thanks for the help.
                            I have tried the expression ^[a-zA-Z0-9 \-_]*$
                            And this is working as per requirements but when it is declared within mxml
                            tag of RegExpValidator.
                            Actually I have to use this condition at many places and that's why I have
                            marked it as "Static Const".
                            So please tell me a way by which I can avoid the problem of "not properly
                            working of this expression when taken as variable"..
                            It is working when :--
                            <mx:RegExpValidator id="regExpValidator"
                                                        source="" property="text"                             expression="^[a-zA-Z0-9 \-_]*$"                             noMatchError="" enabled="false"/> But it is not working properly when the condition:-- <mx:RegExpValidator id="regExpValidator"                             source="" property="text"
                            expression="{TCConstants.TEMPLATE_NAME_REGULAR_EXPRESSION}"
                                                        noMatchError=""
                            enabled="false"/>
                            Thank you once again...
                            • 12. Re: RegExp for excluding special characters in a string.
                              _spoboyle Level 4
                              I found a way to move the regex into a variable
                                        <fx:Script>
                                        <![CDATA[
                                                  private static const exp106:RegExp = /^[a-zA-Z0-9 \-_]*$/;
                                        </fx:Script>
                                        <fx:Declarations>
                                                            expression="{exp106.source}" source="{textBox}"
                                        </fx:Declarations>
                                        <mx:VBox>
                                        </mx:VBox>
                              </s:Application>
                              • 13. Re: RegExp for excluding special characters in a string.
                                munira06 Level 1
                                Hey many many thanks for solving this issue.
                                Once again  thanks to you a lot
                                Regards
                                Munira
