2 Replies Latest reply on Apr 22, 2012 8:25 AM by appie-s
    Slow performance on Mac.
    appie-s Level 1
      Thanks Steve, will continue here.
      I really would like a solution. Sorry I sounded like that but I was a bit (a lot) frustated.
      My camera is: JVC GZ-HM335
      Resolution: 1920x1080 pixels, 24Mbps
      Project settings I don't remenber but should be PAL 1920x1080i
      Mac: Intel i7, 8gb ram
      It's almost impossible to move around in prel.
      Thanks in advance.
        • 1. Re: Slow performance on Mac.
          When you first import your video into your project, is there a red line over the timeline?
          If yes, that means your project is not correct for your video
          Read Bill Hunt on a file type as WRAPPER http://forums.adobe.com/thread/440037
          What is a CODEC... a Primer http://forums.adobe.com/thread/546811
          What CODEC is INSIDE that file? http://forums.adobe.com/thread/440037
          Report back with the codec details of your file, use the programs below... a screen shot works well to SHOW people what you are doing
          For PC http://www.headbands.com/gspot/ or http://mediainfo.sourceforge.net/en
          For Mac http://mediainspector.massanti.com/
          http://blogs.adobe.com/premiereprotraining/2011/02/red-yellow-and-green-render-bars.html
          If you have a red line over the timeline after importing a video and before adding any effects... your project is wrong for your video... read above about codecs
          Once you know exactly what it is you are editing, report back with that information... and your project setting, and if there is a red line above the video in the timeline, which indicates a mismatch between video and project
          H.264 will NOT work inside an AVI http://forums.adobe.com/thread/854115
          More information needed for someone to help... click these links and provided the requested information
          -http://forums.adobe.com/message/4200840
          -http://forums.adobe.com/thread/416679
          • 2. Re: Slow performance on Mac.
            appie-s Level 1
            Hello John,
            There is no red line in Timline while imporeting the video
            This is the output from MediaInspector:
            * * * Media Inspector 0.7.443 file analysis report.
            * * * Media Inspector is ©2011 by Diego Massanti - http://mediainfo.massanti.com
            * * * MediaInfoLib by Jerome Martinez - http://mediainfo.sourceforge.net
            Created on: 22 apr. 2012 17:21:47 GMT+02:00
            Report for file: Moviem4v.m4v
            General / Container Stream #1
                      Total Video Streams for this File.................1
                      Video Codecs Used.................................AVC
                      File Format.......................................AVC
                      Total File Size...................................2.28 GiB
            Video Stream #1
                      Codec (Human Name)................................AVC
                      Codec Profile.....................................Main@L4.0
                      Frame Width.......................................1 920 pixels
                      Frame Height......................................1 080 pixels
                      Frame Rate........................................25.000 fps
                      Display Aspect Ratio..............................16:9
                      Video Standard....................................PAL
                      Scan Type.........................................Interlaced
                      Scan Order........................................TFF
                      Color Space.......................................YUV
                      Codec Settings (Summary)..........................CABAC / 3 Ref Frames
                      QF (like Gordian Knot)............................0.287
                      Codec Settings (CABAC)............................Yes
                      Codec Settings (Reference Frames).................3
                      Video Stream BitRate..............................14.9 Mbps
                      Video Stream BitRate Mode.........................CBR
                      Bit Depth.........................................8 bits
