0 Replies Latest reply on Apr 22, 2012 7:35 AM by dv8kiwi
    I have a Flash file to be used in a Flex project, which outputs a SWC OK in 5.5, but not in 5.0
    dv8kiwi Level 1
      I have a Flash file to be used in a Flex project, which outputs a SWC OK when publishing in 5.5, but not in 5.0. It needs to be edited and output by somebody using 5.0, and is saved in 5.0 format, but they are unable to publish because it does not produce a SWC. What are the likely causes? All publish settings are maintained across both versions, but only 5.5 produces a SWC.
