4 Replies Latest reply on Apr 22, 2012 9:17 AM by nefl777
    configuration advice; I'm in need of adding disk space on an iMac
    nefl777 Level 1
      Hi guys,
      Before I went ahead and bought stuff I thought I would pass this by you. Right now, I've been using an iMac with for the last 2 years with this config:
      Processor : Intel Core i5
        Speed: 2.66 GHz
        Number Of Processors: 1
        Total Number Of Cores: 4
        L2 Cache (per core):  256 KB
        L3 Cache: 8 MB
        Memory: 8 GB
      my graphics card:          ATI Radeon HD 4850
        Type:          GPU
      Disk: Internal Serial-ATA  7200 rpm disk; 1TB capacity
      My camera is a Canon XHa-1s which is HDV format. I capture using my single firewire 800 port. My adobe version is 5.5.  My performance is absolutely fine. However, I'm finding that I run out of disk space on the 1TB drive and am always cleaning things up.
      I'm considering adding an external drive which would connect to that same port. Therefore, I'm considering using a hub that would connect to the external drive AND the camera. so the footage would come from the camera and go onto the disk at the same time.  Here is the hub:
      http://www.belkin.com/IWCatProductPage.process?Product_Id=608525
      Is this a totally stupid idea for performance? Has anyone used this successfully ? Advice ?
      thanks guys!
