9 Replies Latest reply: Apr 28, 2012 9:22 AM by bmohnsen RSS
    Creating own controller
    bmohnsen Community Member
      There are parts of my movie where I want the user to have complete control. So I created a controller with step back, pause, step forward, play.
      Any help with script would be appreciate. I have tried go to the frame for stop --- and even put it in a loop - but it doesn't stop
      I have tried frame+1 for step forward without any lock.
      How do control frame movement.
      I would prefer not to use markers - because the count would be in the thousands.
        • 1. Re: Creating own controller
          SeanWilson Community Member
          When you say
          are you talking about your Director movie or a video file you have playing on the stage?
          • 2. Re: Creating own controller
            Director movie
            • 3. Re: Creating own controller
              And so you're wanting a controller something like the QuickTime controller, with a play/apuse button and a sliding scrub bar?
              • 4. Re: Creating own controller
                Yes - thank you
                • 5. Re: Creating own controller
                  Production Monkey Community Member
                  One way to approach this is to place all the logic for controling the position of the timeline in a parent script and then use a global exitFrame handler inside a movie script to route the call to an instance of the parent script.
                  It's simpler than it sounds.
                  Here's the movie script:
                  global gControler
                  on prepareMovie
                    gControler = script("Timeline Controler").new(#play)  -- #play, #pause, #reverse. [speed] optional speed value
                  end
                  on exitFrame
                    gControler.updateFrame()
                  end
                  Now you can control the flow of the timeline via the global object "gControler" which I provide below.
                  The interface is:
                  gControler.play(), gControler.play(3), etc
                  gControler.reverse(), gControler.reverse(2), etc
                  gControler.pause()
                  gControler.jump(1), gControler.jump(10), etc
                  gControler.seek(10), gControler.seek(1000), etc
                  Any exitFrame handlers in FrameScripts will override the movieScript exitframe handler. Which you may or may not want to do.
                  Paste the following in to a parent script named: "Timeline Controler"
                  -- Parent Script Timeline Controler
                  property  pState  -- #play, #pause, #reverse
                  property  pSpeed  -- frames per exitFrame. Normal play rate is 1.
                  on new me, aState, speed
                    if aState.SymbolP then
                      pState = aState
                    else
                      pState = #play
                    end if
                    if Not [#play, #pause, #reverse].getPos(pState) then pState = #play
                    if speed.IntegerP then
                      pSpeed = speed
                    else
                      pSpeed = 1
                    end if
                    return me
                  end new
                  -- change current frame based on state variable pState
                  on updateFrame me
                    case pState of
                      #play:       go(min(_movie.frame + pSpeed, _movie.lastframe))
                      #reverse:  go(max(1, _movie.frame - pSpeed))
                      #pause:    go(_movie.frame)
                    end case
                  end updateFrame
                  -- go forwards
                  on play me, speed
                      pSpeed = speed
                    else
                      pSpeed = 1
                    end if
                    pState = #play
                  end play
                  -- go backwards
                  on reverse me, speed
                      pSpeed = speed
                    else
                      pSpeed = 1
                    end if
                    pState = #reverse
                  end reverse
                  -- loop on a frame
                  on pause me
                    pState = #pause
                  end pause
                  -- move "pos" number of frames from current position. Can be positive or negative
                  on jump me, pos
                    if pos.IntegerP then
                      go(max(1, min(_movie.frame + pos, _movie.lastframe)))
                    end if
                  end jump
                  -- go to an absolute position on the timeline
                  on seek me, pos
                      go(max(1, min(pos, _movie.lastframe)))
                    end if
                  end seek
                  • 6. Re: Creating own controller
                    Wow - thank you so much
                    • 7. Re: Creating own controller
                      on prepareMovie
                      end
                      Do you create
                      for pause and reverse as well?
                      gControler = script("Timeline Controler").new(#pause)
                      gControler = script("Timeline Controler").new(#reverse)
                      • 8. Re: Creating own controller
                        I am getting an object expected error.
                        Here is the code I have in my movie script
                        global gControler
                        on prepareMovie
                        end
                        on exitFrame
                          gcontroler.updateFrame()
                        end
                        Then I used the code you gave me and put it in a parent script.
                        Then I created four buttons - back, pause, play, forward
                        Back:
                        global gControler
                        on mouseEnter()
                          cursor 280
                        end mouseEnter
                        on mouseLeave()
                          cursor -1
                        end mouseLeave
                        on mouseup
                          gControler.reverse(1)
                        end
                        Play:
                        global gControler
                        on mouseEnter()
                          cursor 280
                        end mouseEnter
                        on mouseLeave()
                          cursor -1
                        end mouseLeave
                        on mouseup
                          gControler.play()
                        end
                        Forward:
                        global gControler
                        on mouseEnter()
                          cursor 280
                        end mouseEnter
                        on mouseLeave()
                          cursor -1
                        end mouseLeave
                        on mouseup
                          gControler.play(1)
                        end
                        Pause:
                        global gControler
                        on mouseEnter()
                          cursor 280
                        end mouseEnter
                        on mouseLeave()
                          cursor -1
                        end mouseLeave
                        on mouseup
                          gControler.pause()
                        end
                        • 9. Re: Creating own controller
                          Got it
                          had to just gControler.jump
