3 Replies Latest reply on Apr 22, 2012 7:32 PM by Jim_Simon
    Quicktime Clip interlace problems. CS5
    $gmillionaire
      I have two reel length clips that make a feature length movie that have been encoded for me at a post house and I just need to put them together and burn them to DVD.  This issue is that I can see the interlacing in the footage during certain scenes and through transitions.  The title crawl at the end jumps a bit as well.  The specs for the clips are below. The eventual destination is DVD through Encore.  I have done mostly episodic work batched from tapes so I have never had to deal with this. I have tried messing with the fields and making it progressive. I have burned allot of test DVD's trying different things through encore and nothing so far has worked.  The hardware is a purpose built PC system and plays it just fine except for these flaws.  Do I need to bring it down to 8 bit? If so how would I do that.  Any help would be wonderful!
      Here is the clips properties.
      Quicktime Movie
      Image Size 720 X 486
      Pixel Depth 24
      Frame Rate 29.97
      Average Data Rate 27.2 MB/second
      Average Frame Rate 29.98 FPS
      Uncompressed 10 bit.
      Thank you for your time and your help!
