5 Replies Latest reply on Apr 26, 2012 9:59 AM by neal204
    Creating a 'rope' connecting two sprites which rotates dynamically
    neal204
      Hi, I'm working on a game which involves the character shooting a hook which is connected to the character by a rope. the character follows the hook once it lands and hangs beneath it. The trouble is getting a rope to connect the rope and the sprite and rotate dynamically with the changing position. I already have code changing the length of the rope sprite to fit and position it between the hook and the character, the problem is getting the sprite to rotate properly so it is always connected to the character and the hook. any ideas? already tried calculating the angle and adding that to the sprite.rotation value, pretty stuck.
        • 1. Re: Creating a 'rope' connecting two sprites which rotates dynamically
          Production Monkey Level 3
          Did you set the registration point of the rope bmp to the end that is "connected" to the hook?  I'm guessing that is the point you want to rotate about.
          Calculating the angle and using sprite.rotation sounds like the way to do it. Someone might be able to help you with your code if you post it.
          • 2. Re: Creating a 'rope' connecting two sprites which rotates dynamically
            neal204 Level 1
            i have been trying that, but the problem seems to be lingos math functions. using atan(o/a) to find the angle always results in zero. the rope is set to be in the mid point of the character and the hook, as the length changes dynamically to stretch between them. i set the .height of the sprite to the distance between the char and hook. ill post the code when i get on director.
            • 3. Re: Creating a 'rope' connecting two sprites which rotates dynamically
              Wolfgang Herold Level 2
              ----   using atan(o/a) to find the angle always results in zero----
              you must not use integers in the division.
              Maybe that's why the result is zero.
              e.g.
              integer:       2/3 = 0
              float:            2.0 / 3.0 = 0.66666666666
              • 4. Re: Creating a 'rope' connecting two sprites which rotates dynamically
                Here's a sample behavior that may do what you are trying to do. I used a black horizontal line for my "rope" with its reg point set to the left side. The code changes the rope's width, but you can change that to height.
                --  Rope Connecter Behavior
                property  pMe
                property  pRotationPointSprite
                property  pSpriteToTrack
                On GetPropertyDescriptionList me
                  Props = [:]
                  Props[#pRotationPointSprite] = [#default:sprite(1), #format:#sprite,  #comment:"Sprite that rope rotates about."]
                  Props[#pSpriteToTrack] = [#default:sprite(1), #format:#sprite,  #comment:"Sprite that the free moving end of the rope tracks."]
                  return Props
                end GetPropertyDescriptionList
                on beginSprite me
                  pMe = sprite(me.spriteNum)
                  me.enterFrame()
                end beginSprite
                on enterFrame me
                  AnchorLoc = pRotationPointSprite.loc
                  TrackLoc = pSpriteToTrack.loc
                  pMe.loc = AnchorLoc
                  DeltaH = TrackLoc.locH - AnchorLoc.locH
                  DeltaV = TrackLoc.locV - AnchorLoc.locV
                  RopeLength = sqrt(DeltaH * DeltaH + DeltaV * DeltaV)
                  pMe.width = RopeLength
                  pMe.rotation = me.getAngle(DeltaH, DeltaV)
                end enterFrame
                on getAngle me, deltaH, deltaV
                  if deltaH <> 0 then
                    slope = float (deltaV) / deltaH
                    angle = atan (slope)
                    if deltaH  < 0 then
                      angle = angle + pi
                    end if
                    if angle < 0 then
                      angle = angle + (2 * pi)
                    end if
                  else if deltaV > 0 then
                    angle = pi / 2
                  else if deltaV < 0 then
                    angle = (3 * pi) / 2
                  else
                    angle = 0
                  end if
                  return angle * 180 / pi
                end getAngle
                • 5. Re: Creating a 'rope' connecting two sprites which rotates dynamically
                  neal204 Level 1
                  thanks alot, this seems to have fixed most of the issues, the rope takes a little while to update its rotation on longer distances, but other than that its great, thanks alot
