4 Replies Latest reply on May 10, 2012 1:34 PM by Dean Bruyere
    if then statement is what i believe i may need
    Dean Bruyere
      I have a drop down list with several items in it, i would like another textfield to display an universal number if i select one of the specific items in my dropdown list,, I am really new at this and learning
        • 1. Re: if then statement is what i believe i may need
          paulk07 Level 3
          You can control for each item.  Please provide what you would want in the droplist and the values to display and I'll build a quick sample
          • 2. Re: if then statement is what i believe i may need
            Dean Bruyere Level 1
            I realize now some of my issues, i have a globy file which contains a preset number of fields in it,each preset field contains a certain unique number associated with it...when i select from a previous dropdown list  that contains other fields the values in each of those fields will change from its unique number to a common number.....
            The first drop list contains the following items
            set, consolidated, integrated,  transitional, flex, flexible transfer and a few others, The values only change to one other value doesnt matter which i select.
            The second dropdown list is the globy file which contains the following
            function globya()
            switch  (sNewSel)
            case "Aboriginal Diabetes Initiative":
            AC = "KC01"
            GL = "76721"
            break;
            there are many more items listed and i didnt want to add them here but the only item I would like to change is the GL to an universal number which would be 76709
            I hope this helps explain otherwise I could send you the complete form that I have, thanx in advance
            • 3. Re: if then statement is what i believe i may need
              paulk07 Level 3
              The event is set to "initialize" and this is javascript on the droplist object:
              Assuming you have textfields named AC & GL.
              var sNewSel = this.rawValue;
              switch (sNewSel)
                  xfa.form.form1.BodyPage1.AC.rawValue="KC01";
                  xfa.form.form1.BodyPage1.GL.rawValue="76721";
                  break;
              Copy the script and add your other options between the brackets
              • 4. Re: if then statement is what i believe i may need
                thanx for your help but i  need to get away from this for a while, im a wee bit frustrated and it doesnt seem to work. Basically when i select from "set" and consolidated in the first droplist the values in the globy file remain the same...its when i select transitonal, integrated flex and flexible transfer I would like the values to change in the globy file to change from the default gl to a new number which is always 76709
