1. Re: Insert editable picture into PDF form?
Gilad D (try67) Apr 24, 2012 9:37 AM (in response to LillypadDesignWorks)Are the users also using Acrobat, or Reader? If the latter, it can only be done with a form created in LiveCycle.
2. Re: Insert editable picture into PDF form?
LillypadDesignWorks Apr 24, 2012 12:52 PM (in response to Gilad D (try67))I would prefer they be able to use Reader but it's not absolutely necessary. How do you go about it if the users will be using acrobat?
Thanks!
3. Re: Insert editable picture into PDF form?
Gilad D (try67) Apr 24, 2012 12:57 PM (in response to LillypadDesignWorks)You can create a button and add a script to it that would prompt the user
to select an image file when that button is clicked. Then that image can be
displayed using the same button (buttons can show either an image or text).
4. Re: Insert editable picture into PDF form?
LillypadDesignWorks Apr 24, 2012 1:05 PM (in response to Gilad D (try67))Thanks so much for your help! I'm going to try and work with it and see how it goes. I've never added script before.
You've been so helpful, I really appreciate you sharing your knowledge!
5. Re: Insert editable picture into PDF form?
Gilad D (try67) Apr 24, 2012 1:11 PM (in response to LillypadDesignWorks)The script in question is:
event.target.buttonImportIcon();
You need to add it as an Run a JavaScript-action to your button, triggered
by the MouseUp event, and of course set the button's layout to "Icon Only"
before-hand.
6. Re: Insert editable picture into PDF form?
LillypadDesignWorks Apr 24, 2012 7:18 PM (in response to Gilad D (try67))Wow! Worked perfectly. Thanks so much for the instructions. It saved me a TON of time and messing around. Again, thanks for your expertise!
7. Re: Insert editable picture into PDF form?
phcpdesign Sep 6, 2012 2:11 PM (in response to Gilad D (try67))I also was needing this information, thank you. But when you insert a picture into the button, it is only allowing the enduser to insert a pdf into the picture button. How do I enable them to insert jpg, gif, png etc? My endusers will not be technologically savvy and will just be entering information into the given fields...
Thanks!
8. Re: Insert editable picture into PDF form?
Test Screen Name Sep 6, 2012 2:19 PM (in response to phcpdesign)I read that Adobe Reader doesn't include anything to do image file conversion to PDF. So it could only add PDFs.
9. Re: Insert editable picture into PDF form?
George Johnson Sep 6, 2012 2:19 PM (in response to phcpdesign)It defaults to PDF, but you can change it to whatever format Acrobat is capable of converting to PDF, which includes many image formats.
10. Re: Insert editable picture into PDF form?
George Johnson Sep 6, 2012 2:23 PM (in response to Test Screen Name)Test Screen Name wrote:
It (buttonImportIcon) doesn't work with Reader (6-10). It simply isn't available, regardless of usage rights, execution context, or anything else.
11. Re: Insert editable picture into PDF form?
phcpdesign Sep 6, 2012 2:26 PM (in response to George Johnson)great! How does one go about changing this preference? I only have experience with normal text fields, so thank you so much for your expertise!
12. Re: Insert editable picture into PDF form?
George Johnson Sep 6, 2012 2:39 PM (in response to phcpdesign) -
13. Re: Insert editable picture into PDF form?
phcpdesign Sep 6, 2012 2:42 PM (in response to George Johnson)I see what you mean now. Thank you so much! we will be sure to include that with their instructions
14. Re: Insert editable picture into PDF form?
phcpdesign Sep 7, 2012 9:11 AM (in response to phcpdesign)Hello Forum,
I'm back. The picture information worked great - for Macs. Is there a script that works on both Mac and PC? When the PC user mouses over, the hand shows up and highlights the button, but when they click it, there is no prompt for inserting a file. Is there something else I need to do? Would I have both scripts on there so it can be used by either pc or mac - i did see there was an 'add' button where the scripts go. Most likely it will only be a PC user with the pdf in the end, so that is more important as i can make a file for the mac user.
thanks so much for you help!
15. Re: Insert editable picture into PDF form?
George Johnson Sep 7, 2012 9:49 AM (in response to phcpdesign)As stated, this will not work with Reader. Can you confirm that the Windows user is using Acrobat?
16. Re: Insert editable picture into PDF form?
phcpdesign Sep 7, 2012 10:27 AM (in response to George Johnson)Ah, i did not really read that 'fine print'. they are just using reader. they will be filling out the form. so is there no way for them to insert a picture in an editable pdf? I'm just making a basic form and all other fields work, we just need to be able to enter in an image. will we just have to make a template in Word? please say it isnt so....
17. Re: Insert editable picture into PDF form?
George Johnson Sep 7, 2012 10:38 AM (in response to phcpdesign)If you have LiveCycle Designer, which comes with Acrobat Pro for Windows (but not Mac), you can create a form that includes an image field. Otherwise, we have to hope that they decide to restore this feature to Reader in the future, something for which I remain hopeful: http://forums.adobe.com/thread/743823
18. Re: Insert editable picture into PDF form?
phcpdesign Sep 7, 2012 10:59 AM (in response to phcpdesign)thank you so much. sorry for your need to be repetitive as i looked over that information before. i appreciate all your help!
19. Re: Insert editable picture into PDF form?
5iveMEDIA Jul 9, 2013 10:29 AM (in response to George Johnson)I'm wondering if by today's date: 07/09/13; this feature is available for the acrobat pdf.
Specificly, for a work order; I want to place a google map and a street view image of the customer's home.
20. Re: Insert editable picture into PDF form?
M-Z-Jay Sep 13, 2013 8:57 AM (in response to 5iveMEDIA)If you have access to livecycle I have just found the following which may help...
21. Re: Insert editable picture into PDF form?
raemurph Feb 6, 2014 12:50 PM (in response to Gilad D (try67))Thanks - this was helpful but how do I get the form to be blank - it wants to keep the last picture I put up....is there a way to clear it so that I can save it as a cleared document?
22. Re: Insert editable picture into PDF form?
George Johnson Feb 6, 2014 12:55 PM (in response to raemurph)Here's a sample PDF that shows how you can do this: https://workspaces.acrobat.com/?d=Y8yNh5pIkMTlreBhZ5CUHQ
23. Re: Insert editable picture into PDF form?
SoftwareEngineer8876 Mar 7, 2014 1:58 PM (in response to LillypadDesignWorks)How i can insert image in adobe reader PDF with mouse pointer or cursor ?
Dear, I need help so someone help me?
i did make the PDF and insert image in PDF ..
i want when i open the PDF file in adobe reader and click on image with the mouse cursor ..
then open the dialog box and i can insert new image in PDF on the previous image...
it must i want this work in adobe reader only not in adobe acrobat....
i want to insert image in adobe reader only with the mouse pointer or cursor
