1 Reply Latest reply on Oct 15, 2012 4:16 AM by domnic.rj23
    Passing arguments to jsx file externally
      I have a script (javascript, jsx) that will parse content from InDesign (.indd) documents using InDesignServer. I want to be able to pass the filename, as well as the path of the indesign file as parameters to this script.
      I have tried this vbs solution:
      Option Explicit
      On Error Resume Next
      Dim appRef
      Dim javaScriptFile
      Set appRef = CreateObject( "Photoshop.Application" )
      javaScriptFile = "C:\myscript\test.jsx"
      call appRef.DoJavaScriptFile( javaScriptFile, Array(Array("one","two"), Array("three")), 1)
      DoJavaScriptFile takes 3 params, the first being the script, the 2nd is an array of params. In my example, you can have an array of arrays of params. When you receive params from javascript side, it will see param 0 as (one, two), param 1 is (three). For most people, simple case is fine: eg:
      call appRef.DoJavaScriptFile( javaScriptFile, Array("one","two", "three"), 1)
      The javascript would look like this:
      #target photoshop
      if (arguments.length > 0)
      alert("ARGUMENT 0 = " + arguments[0]);
      from the jsx side, there's a magical variable called "arguments" of array type. When you pass variables in, the 1st one will be arguments[0], the next one would be arguments[1], and so forth.
      To execute this from command line, (assuming everything lives in c:\myscript):
      cscript c:\myscript\runjavascript.vbs
      This approach does not work, because I get an error from the CreateObject function, it cannot create an object for InDesignServer.Application.
      Ideally, I want to be able to pass arguments from a python script to a jsx script.
      InDesign CS4 .indd documents
      Win2k8 server
      JavaScript (via ExtendScript toolkit)
      InDesignServer CS5.5 (32bit)
      SmartLayout plugin
