2 Replies Latest reply on Apr 23, 2008 5:18 PM by srenker1
    Error Publishing, Very very frustrated.
    latro_
      Hi there
      This is my last port of call as I cannot figure this one out, I have spent hours trying to no positive result.
      I have used Contribute on other servers fine, however a client is using one out side of our network and I am having issues with publishing drafts.
      I have tried:
      alt publish method, passive ftp, non passive ftp, optimized on, optimized off and all combinations thereof.
      However everytime I click 'publish' contribute says 'waiting for server' and after 30 seconds or so the following error message pops up:
      'Contribute could not connect because the server is down or not accepting connections. Please contact your administrator.'
      I have checked the server and a .LCK file is created and also there is an _mm directory.
      I have had zero problems using both dreamweaver and filezilla to FTP into this server and add/mod/delete both directories and files so i cannot see it being a permissions issue.
      I have also tested using the Adober Server checker tool which resulted in the log attached at the end of this message (login details taken of course).
      I really am lost for any ideas or anything else to try. This could spell the end of our company using contribute as a content management tool if not upto the job :(
      any help apreciated,,, alot!
      Nick M
      Date: 4/4/2008
      LocalTime: 13:17
      Host: *removed*
      Port: 21
      LoginID: *removed*
      FTP Path: /httpdocs/
      Passive Enabled: false
      ProxyHost: N\A
      Contribute Alternate Rename: no
      Contribute Optimized: no
      ======================== Test Results ==========================
      NOTE: Microsoft FTP Service has been detected.
      For more information on FTP server compatibility issues, please see:
      http://www.macromedia.com/support/contribute/ts/documents/ftp_info.htm
      Login: SUCCESS!
      Changing Directory To : /httpdocs/
      SUCCESS!
      Directory Listing Test: SUCCESS!
      Make Directory Test: SUCCESS!
      Change Directory Test: SUCCESS!
      Upload a File Test: SUCCESS!
      Fallback Test for Optimization: SUCCESS!
      Server State Test: Unkown error was thrown
      .Please send this code to Macromedia: 5
      -------------------------------- FTP log from the last operation -------------------------------
      > CWD /httpdocs/mm_diagnose
      < 250 CWD command successful.
      > PORT 192,168,16,30,16,152
      < 200 PORT command successful.
      > TYPE A
      < 200 Type set to A.
      > LIST
      < 150 Opening ASCII mode data connection for /bin/ls.
      < 04-04-08 01:34PM 27 upload_test1_reg_.mm
      < 226 Transfer complete.
      Cleaning Test File: SUCCESS!
      Cleaning Test Directory: SUCCESS!
