5 Replies Latest reply on May 22, 2012 10:11 AM by kswezy
    How do I get the histogram to give me an accurate reading?
    kswezy Level 1
      I use the histogram feature in PS to help me figure out how many square feet of yarn I will use in a rug that I am making (I work as a rug designer). I am running into a problem with this which is scary because my numbers have to be accurate.
      As an example, I may have a 9x12 (inch--this is later blown up to feet using a transparency) drawing. In the drawing there may be 45 organic looking shapes that will be green. I use the magic wand tool and choose all of these green shapes. What I am noticing is that once I get to a certain number (not always consistent) in the histogram reading it will all of a sudden change to a different number and go to (for example) Cache 3. Because of this I have no idea if my histogram reading is accurate.
      Is this some sort of memory issue? How do I prevent this from happening so that I can get an accurate histogram reading?
      Thanks so much. Once this gets figured out I will be so less stressed out! I am new to this job and trying to not start out by making huge and expensive mistakes!
      Kathryn
