2 Replies Latest reply on Apr 24, 2012 4:25 PM by kremisi
    GREP text selection between words
    kremisi Level 1
      I'd like to select all the text contained between [2A] and [F2A].
      The problem is that there are n paragraph between the 2 items as in the following example:
      [2A]
      Lorem ipsum dolor sit amet.
      [MOI] Lorem ipsum dolor sit amet.
      [ROI] Lorem ipsum dolor sit amet.
      [F2A]
      I tried:
      (\[2A\]).+(\[F2A\])
      But there are maybe more than one mistake in my code. Any suggestion?
        • 1. Re: GREP text selection between words
          Put "(?s)" at the start of your GREP to force "single-line" mode.
          By default, GREP only works on a single paragraph, and so it will stop searching when it encounters a hard return. Setting single-line mode makes it treat the hard return as any other regular character.
          You might want to change the ".+" in the middle of your expression to ".+?", to make it match the shortest possible string. Default is GREP grabs as much as possible, so if you have these codes more than once in a text, it will happily select all from the very first to the very last instance.
          • 2. Re: GREP text selection between words
            kremisi Level 1
            I could not imagine the great Jongware replied to my post :-)
            The final code is:
            (?s)(\[2A\]).+?(\[F2A\])
            Thanks!
