2 Replies Latest reply on Apr 25, 2012 5:23 AM by Manish-Sharma
    Can't print .indd booklet to PDF; opens print utility instead of Acrobat
      Thanks in advance for any help you can lend.
      I have a 16 page .indd document that I'm trying to export via "print booklet", using Adobe PDF 9.0 as my printer. Every time I try to print as a PDF, it goes through the process of compiling the images, loading fonts, etc., but then my printer utility opens (obviously giving an error) instead of Acrobat. When I just choose export as PDF I have no issues whatsoever; Acrobat opens and it saves properly. I need the document, though, in a saddle stitch imposed format for the printer.
      I'm on Mac OSX Lion 10.7.2
      Acrobat X version 10.1.3
      Adobe InDesign CS5.5
      The setting summary of the print dialogue is as follows:
      Print Preset: [Custom]
      Printer: Adobe PDF 9.0
      PPD: Adobe PDF 9.0
      PPD File: /var/folders/74/_l7wb86j7plcvb5kz2hwgmh00000gn/T//4f9757064d509
      Print Booklet
          Booklet Type: 2-up Saddle Stitch
          Auto Adjust Margins: On
          Top Margin: 0.2917 in
          Bottom Margin: 0.2917 in
          Left Margin: 0.2917 in
          Right Margin: 0.2917 in
          Space Between Pages: N/A
          Creep: 0 in
          Bleed Between Pages: N/A
          Signature Size: N/A
          Print Blank Printer Spreads: On
          Copies: 1
          Collate: Off
          Reverse Order: Off
          Pages: All
          Sequence: All Pages
          Spreads: Off
          Print Master Pages: Off
          Print Layers: Visible & Printable Layers
          Print Non-printing Objects: Off
          Print Blank Pages: Off
          Print Visible Guides and Baseline Grids: Off
          Paper Size: Tabloid Oversize
          Paper Width: 12 in
          Paper Height: 18 in
          Page Orientation: Landscape
          Paper Offset: 0 in
          Paper Gap: 0 in
          Transverse: Off
          Scaling: 100%
          Constrain Proportions: On
          Page Position: Centered
          Thumbnails: Off
          Tiling: Off
      Marks and Bleed
          Crop Marks: On
          Bleed Marks: Off
          Registration Marks: Off
          Color Bars: Off
          Page Information: Off
          Printer Mark Type: Default
          Crop Mark Weight: 0.25 pt
          Mark Offset from Page: 0.0833 in
          Use Document Bleed Settings: On
          Bleed Top: 0 in
          Bleed Bottom: 0 in
          Bleed Inside: 0 in
          Bleed Outside: 0 in
          Include Slug Area: Off
          Color: Composite CMYK
          Text As Black: Off
          Trapping: Off
          Flip: None
          Negative: Off
          Screening: Default
          Simulate Overprint: Off
          Frequency: 60
          Angle: 45
          Send Data: Optimized Subsampling
          Download: Complete
          Download PPD Fonts: On
          PostScript®: Level 2
          Data Format: ASCII
      Color Management
          Document Profile: U.S. Web Coated (SWOP) v2
          Color Handling: Let InDesign Determine Colors
          Printer Profile: Document CMYK - U.S. Web Coated (SWOP) v2
          Preserve CMYK Numbers: On
          Proof Profile: Document CMYK
          Simulate Paper Color: On
          Print &as Bitmap: On
          Bitmap Resolution: 300
          OPI Image Replacement: Off
          EPS: Off
          PDF: Off
          Bitmap Images: Off
          Transparency Flattener Preset: [Medium Resolution]
          Ignore Spread Overrides: Off
