1 Reply Latest reply on Apr 25, 2012 4:59 AM by Velprakash
    Problem in saving the applied Tag.
    Velprakash
      Hi All,
            I created 4 tags manually in cs5. It named b, bi, i, sc for (bold, bolditalic, italic, small caps) already there's a tag default as root.
      I want to find bold, italic, bolditalic, small caps words in a document and applying appropriate tags.If I applied tags and then making another word in a document as bold and running this Jx file, It finding correctly. But not able to save the tag applied for new word which is created as bold.
      xmlObj[0].name=b;
      xmlObj[1].name=bi;
      xmlObj[2].name=i;
      xmlObj[3].name=root;
      xmlObj[4].name=sc;
      I also need to mention to apply tagname instead of specifying the above lines.
      My code is below. Please some one guide me...
      docObj=app.activeDocument;
      xmlObj = docObj.xmlTags;
      pageObj=docObj.pages.item(0);
      myTextFrame=pageObj.textFrames.item(0);
      myText=myTextFrame.parentStory.paragraphs.item(0);
      app.findTextPreferences = app.changeTextPreferences =  NothingEnum.nothing;
      app.findTextPreferences.fontStyle = "Bold";
      result = app.activeDocument.findText();
      boldlength=0;
      boldlength=result.length;
      alert(boldlength);
      for (i=0; i<boldlength;i++)
              var myElem=result[i].associatedXMLElements[0].markupTag.name;
              alert(myElem);
              if(myElem==xmlObj[0].name)
                  alert("No need to apply");
              else
                  myElem=xmlObj[0].name;
                  //result[i].changeTextPreferences.markupTag=xmlObj[0].name;
                  //app.changeTextPreferences.markupTag=xmlObj[0].name;
                  alert("apply tag:" +myElem);
                  app.changeTextPreferences.result[i].=myElem.changeText();
      //~ app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
      //~ app.findTextPreferences.fontStyle = "Bold Italic";
      //~ app.changeTextPreferences.markupTag=xmlObj[1].name;
      //~ alert(app.changeTextPreferences.markupTag);
      //~ app.activeDocument.changeText();
      //~ app.findTextPreferences.fontStyle = "Italic";
      //~ app.changeTextPreferences.markupTag=xmlObj[2].name;
      //~ app.findGrepPreferences = app.changeGrepPreferences = NothingEnum.nothing;
      //~ app.findGrepPreferences.capitalization = Capitalization.SMALL_CAPS;
      //~ app.changeGrepPreferences.markupTag=xmlObj[4].name;
      //~ alert(app.changeGrepPreferences.markupTag);
      //~ app.activeDocument.changeGrep();
        • 1. Re: Problem in saving the applied Tag.
          Velprakash Level 1
          Correct Codes:
          boldlength=0;
          //alert(boldlength);
                  //alert(myElem);
                  if(myElem=="b")
                  else
                      app.select(result[i]);
                      mySel=app.selection[0];
                      docObj.xmlElements[0].xmlElements.add({markupTag:"b", xmlContent:mySel});
          result1 = app.activeDocument.findText();
          boldlength=0;
          boldlength=result1.length;
                  var myElem=result1[i].associatedXMLElements[0].markupTag.name;
                  if(myElem=="i")
                  else
                      app.select(result1[i]);
                      docObj.xmlElements[0].xmlElements.add({markupTag:"i", xmlContent:mySel});
          result2 = app.activeDocument.findText();
          boldlength=0;
          boldlength=result2.length;
                  var myElem=result2[i].associatedXMLElements[0].markupTag.name;
                  if(myElem=="bi")
                  else
                      app.select(result2[i]);
                      docObj.xmlElements[0].xmlElements.add({markupTag:"bi", xmlContent:mySel});
          result3 = app.activeDocument.findGrep();
          boldlength=0;
          boldlength=result3.length;
                  var myElem=result3[i].associatedXMLElements[0].markupTag.name;
                  if(myElem=="sc")
                  else
                      app.select(result3[i]);
                      docObj.xmlElements[0].xmlElements.add({markupTag:"sc", xmlContent:mySel});
          Thanks and Regards,
          Vel...
