1 Reply Latest reply on Apr 25, 2012 8:51 AM by Mylenium
    Text along a circle
    mhossey Newcomer
      Okay, I've watched a tutorial on this, and I think my illustrator preferences might be different or changed up a bit (mac)
      Whenever I click to add text to this  path, it starts the text at a different point on the path instead of directly where I clicked. If you can see it, towards the left side of the circle where it says "path" in green. Thats where I clicked, but as you can see the actual text would start a little further on the right side
      How can I change this
      EDIT
      Also I will add. Once I do type my text it is no longer selectable. After typing I switch up to my direct select tool, and as I hover over the text nothing happens. I cant select it, I can only select the blue bars on the sides of it. I want to be able to select my text also. Shouldnt the blue bars be at the end and the beginning of the text, not so far away from it
        • 1. Re: Text along a circle
          Mylenium Legend
          You posted in the wrong forum, but I think I can answer your question regardless. The green stuff are the snapping info overlays, the text is still always initially placed at the first vertex of a path wit hrespect to the chosen formatting options for kerning/ spacing etc.. You can change that once the text has been created by dragging the text anchor...
          Mylenium
