2 Replies Latest reply on Apr 25, 2012 6:12 PM by shiny01248
    Calculation errors when entering currency formatted numbers
    shiny01248
      I am creating a form that has several fields, all defined as numbers using currency formatting:
      CurrentBase which is the monthly pay rate which the user enters
      CurrentYearly which is the annual pay rate and is calculated as CurrentBase * 12 -- this is read-only
      CurrentOvertime which is an estimate based on 6% of the CurrentYearly and which the user can override.
      As a OnBlur event in CurrentBase I use this code:
      var cYear=this.getField("CurrentYearly");
      cYear.value=this.getField("CurrentBase").value* 12;
      this.getField("CurrentOvertime").value=cYear.value*0.06;
      I also have a CurrentTotal field which is the sum of CurrentYearly and CurrentOvertime, set in the custom calculation script for CurrentTotal as:
      this.getField("CurrentTotal").value=this.getField("CurrentYearly").value+this.getField("Cu rrentOvertime").value;
      Here is the problem:
      If I enter a CurrentBase, such as 1234 my script correctly calculates the CurrentYearly ($14,808.00), CurrentOvertime ($888.48) and CurrentTotal ($15,696.48) correctly.
      Now if I override the CurrentOvertime using something like 555.00 the total calculates correctly, in this case $15,363.00
      But if I type 555. (omitting the decimal values) my CurrentTotal displays as $14,808,555.00
      This seems to be a bug.  Any thoughts on why and how to fix it.
      Bob
