4 Replies Latest reply on Apr 26, 2012 11:46 AM by GaryLA4G
    PE9 Nikon DSLR Clips OK Preview, Black Bars Output
    GaryLA4G
      I've tried everything I can think of but my output to MPEG video narrow black horizontal bars and wide black vertical bars around the video (Windows Media Player).  I read online posts, watched tutorials, done web searches.  All the advice says to either uncheck the "scale to frame" setting or match the source material to the project settings. I've done those and when they didn't work I experimented with other presets (including output settings).  I understand frame size, aspect ratio and scaling but not much else.  Anyway, this matchup *looks* like it should work.  There are mismatches - most obviously the frame rate - but I don't have any alternatives that get me any closer.
      Clip Source:
      Nikon D90 DSLR
      High Speed SD Memory Card
      Clip Properties:
      Type: AVI Movie
      Image Size: 640x424
      Pixel Depth: 24
      Frame Rate: 24
      Source Audio Format: 11025 Hz - 16 bit - Mono
      Project Audio Format: 11025 Hz - 32 bit floating point - Mono
      Average Data Rate: 835 KB/second
      Pixel Aspect Ratio: 1.0
      Project Settings
      480p DSLR 640x480p60
      Editing Mode: DSLR
      Timebase: 59.94fps
      Frame size: 640h 480v (1.0000)
      Frame rate: 59.94 fps
      Pixel Aspect Ratio: Square Pixels (1.0)
      Fields: No Fields (Progressive Scans)
      Audio Sample Rate: 48,000 samples/second
      Computer
      32 Bit Windows 7
