3 Replies Latest reply on Sep 29, 2012 3:51 AM by areohbee
    How to Initialize Export Video Setttings
    woofyman99
      I'd like to initialize the export settings for video in an export plugin but it isn't covered in the SDK documentation.  I opened an export preset in an editor and looked at the table entires but I couldn't get it to work when I set the same table entries from my plugin.
        • 1. Re: How to Initialize Export Video Setttings
          areohbee Level 6
          Did you prefix them with 'LR_' ?
          In case you didn't know, in a preset, there is:
          ['{plugin-id}'].{export-param-name}
          {lr-setting}
          which need to be translated to
          {export-param-name}
          LR_{lr-setting}
          in the export session before beginning the export.
          R
          • 2. Re: How to Initialize Export Video Setttings
            woofyman99 Level 1
            Here's my code:
            function TourBuzzUploadTask.updateExportSettings (exportSettings)
                  exportSettings.LR_videoFormat = '4e49434b-4832-3634-fbfb-fbfbfbfbfbfb'
                 exportSettings.LR_videoPreset = 'SIZE_max'
            end
            • 3. Re: How to Initialize Export Video Setttings
              areohbee Level 6
              Does your code work?
              Video export is confusing. I'm doing my first video export and could not find the info I need in the documentation either.
              Here's my code for determining the target video extension (yuck):
              for i, vp in ipairs( LrExportSettings.videoExportPresets() ) do
                  local name = LrStringUtils.lower( vp:name() ) -- e.g. "Max".
                  if self.exportParams.LR_export_videoPreset:find( name, 1, true ) then -- e.g. "SIZE_max"
                      destExtension = vp:extension()
                      break
                  end
              end
              A totally ad-hoc/empirical hack, but it was the only thing I could find that worked.
              There has got to be a better way!(?) - any ideas???
              Rob
