1. Re: Problem with PremPro 4 combined with CS5 Master Suite-32 bit issue.
Mylenium Apr 26, 2012 7:47 AM (in response to yellowstonemcclung)Run the Creative Suite Cleaner Tool, reinstall from scratch obeying the right order (that is installing CS4 before CS5.5).
Mylenium
2. Re: Problem with PremPro 4 combined with CS5 Master Suite-32 bit issue.
Arpit Kapoor Apr 30, 2012 8:14 AM (in response to yellowstonemcclung)Actually, you may install PPro CS4 & Ae CS4 32 Bit in any sequence as they have a seperate installer. So, try copying the contents of the "Content DVD" to the desktop and then go to "Adobe After Effects and Premiere Pro CS4 for win 32 bit\Adobe CS4" folder and right click on the setup.exe file and "Run it as Administrator" and check if that helps."
3. Re: Problem with PremPro 4 combined with CS5 Master Suite-32 bit issue.
yellowstonemcclung Apr 30, 2012 9:10 AM (in response to Mylenium)Thanks, Mylenium!
I am going to put your suggestion on my radar and give it a try if Arpit's method doesn't work. Thanks so much for your help!! I really appreciate it!
Have a great week...
Mary
4. Re: Problem with PremPro 4 combined with CS5 Master Suite-32 bit issue.
yellowstonemcclung Apr 30, 2012 9:11 AM (in response to yellowstonemcclung)Thanks, Arpit!
I'm going to try your suggestion this afternoon. Thanks for your help and hope you have a great week!!
Mary
