4 Replies Latest reply on Apr 27, 2012 9:57 AM by Mister MUX
    Linear List
    IEatSandvich
      This is my script to sort a list of scores and consequently the names, hits, and bullets fired accordingly when a game is finished, however it does not. (updatescores custom handler is called at the end of the game). list[7] is where the resultant score is initially stored. Any help please?
      on startmovie
        gvName = "Player"
        if gvNameList = void then
          gvNameList = ["Player Name", "Player Name", "Player Name", "Player Name", "Player Name", "Player Name", "Player Name"]
          gvScoreList = [12, 4, 3, 2, 1, 0, 0]
          gvHitsList = [0, 0, 0, 0, 0, 0, 0]
          gvBulletsList = [0, 0, 0, 0, 0, 0, 0]
        end if
      end
      on updatescores
        gvNameList[7] = (gvName)
        gvScoreList[7] = (gvScore)
        gvHitsList[7] = (gvHits)
        gvBulletsList[7] = (gvTotalBullets)
        if gvScoreList[7] > gvScoreList[5] then
          gvScoreList.setAt(6, gvScoreList[5])
          gvNameList.setAt(6, gvNameList[5])
          gvBulletsList.setAt(6, gvBulletsList[5])
          gvHitsList.setAt(6, gvHitsList[5])
        else if gvScoreList[7] > gvScoreList[4] then
          gvScoreList.setAt(5, gvScoreList[4])
          gvNameList.setAt(5, gvNameList[4])
          gvBulletsList.setAt(5, gvBulletsList[4])
          gvHitsList.setAt(5, gvHitsList[4])
        else if gvScoreList[7] > gvScoreList[3] then
          gvScoreList.setAt(4, gvScoreList[3])
          gvNameList.setAt(4, gvNameList[3])
          gvBulletsList.setAt(4, gvBulletsList[3])
          gvHitsList.setAt(4, gvHitsList[3])
        else if gvScoreList[7] > gvScoreList[2] then
          gvScoreList.setAt(3, gvScoreList[2])
          gvNameList.setAt(3, gvNameList[2])
          gvBulletsList.setAt(3, gvBulletsList[2])
          gvHitsList.setAt(3, gvHitsList[2])
        else if gvScoreList[7] > gvScoreList[1] then
          gvScoreList.setAt(2, gvScoreList[1])
          gvNameList.setAt(2, gvNameList[1])
          gvBulletsList.setAt(2, gvBulletsList[1])
          gvHitsList.setAt(2, gvHitsList[1])
          gvScoreList.setAt(1, gvScoreList[7])
          gvNameList.setAt(1, gvNameList[7])
          gvBulletsList.setAt(1, gvBulletsList[7])
          gvHitsList.setAt(1, gvHitsList[7])
        end if
      end
        • 1. Re: Linear List
          Mister MUX
          My suggestion would be to organize your data a bit differently, which will make sorting the data much easier. Rather than 4 seperate linears lists, I would use a single linear list. The elements of that list would be a property list that contains all of the data (name, score, bullets & hits) for a single player. For example if there was only one player it wold look like this:
          [[#name: "Player A", #score: 12, #hits: 0, #bullets: 0]]
          If there were two players it would look like this:
          [[#name: "Player A", #score: 12, #hits: 0, #bullets: 0], [#name: "Player B", #score: 2, #hits: 6, #bullets: 0]]
          And so on...
          So here is a startMovie script that builds a sample data set
          global gvGameData
          on startMovie
            -- build sample data set
            gvGameData = []
            gvGameData.add([#name:"Player A", #score:8, #hits:0, #bullets:0])
            gvGameData.add([#name:"Player B", #score:4, #hits:0, #bullets:0])
            gvGameData.add([#name:"Player C", #score:3, #hits:0, #bullets:0])
            gvGameData.add([#name:"Player D", #score:9, #hits:3, #bullets:0])
            gvGameData.add([#name:"Player E", #score:9, #hits:2, #bullets:13])
            gvGameData.add([#name:"Player F", #score:9, #hits:2, #bullets:6])
            gvGameData.add([#name:"Player G", #score:12, #hits:0, #bullets:0])
          end
          Now you can make a handler that sorts the data. This one uses a standard "Bubble Sort" (Google it for more info). It also allows you to sort the list by mulitple properties. For example you can sort by score, and if two scores are equal, it can sort by hits. If two scores and hits are equal, it can sort by bullets. Here is the sort handler.
          on sortGameData gameData, sortByPropertyList
            repeat while sortByPropertyList.count > 0
              sortProperty = sortByPropertyList[sortByPropertyList.count]
              sortByPropertyList.deleteAt(sortByPropertyList.count)
              repeat with x = 1 to gameData.count
                repeat with y = 1 to gameData.count - 1
                  if gameData[y][sortProperty] < gameData[y+1][sortProperty] then
                    temp = gameData[y+1]
                    gameData[y+1] = gameData[y]
                    gameData[y] = temp
                  end if
                end repeat
              end repeat
            end repeat
          end
          Here is an example usage:
          Presorted list
          [[#name: "Player A", #score: 8, #hits: 0, #bullets: 0], [#name: "Player B", #score: 4, #hits: 0, #bullets: 0], [#name: "Player C", #score: 3, #hits: 0, #bullets: 0], [#name: "Player D", #score: 9, #hits: 3, #bullets: 0], [#name: "Player E", #score: 9, #hits: 2, #bullets: 13], [#name: "Player F", #score: 9, #hits: 2, #bullets: 6], [#name: "Player G", #score: 12, #hits: 0, #bullets: 0]]
          Call the sort handler:
          sortGameData(gvGameData,[#score,#hits,#bullets])
          And now the list looks like this:
          [[#name: "Player G", #score: 12, #hits: 0, #bullets: 0], [#name: "Player D", #score: 9, #hits: 3, #bullets: 0], [#name: "Player E", #score: 9, #hits: 2, #bullets: 13], [#name: "Player F", #score: 9, #hits: 2, #bullets: 6], [#name: "Player A", #score: 8, #hits: 0, #bullets: 0], [#name: "Player B", #score: 4, #hits: 0, #bullets: 0], [#name: "Player C", #score: 3, #hits: 0, #bullets: 0]]
          Notice how it used multiple properties to sort where players tied on score, or hits, etc? Now you will probably want to turn this data into a nicely formatted string so that you can display it in a text member. Here is a handler that might work for you.
          on getDisplayString gameData, propertyList
            displayString = ""
            repeat with playerData in gameData
              repeat with prop in propertyList
                displayString = displayString & playerData[prop] & tab
              end repeat
              displayString = displayString.char[1..displayString.char.count - 1]
              displayString = displayString & return
            end repeat
            return displayString
          end
          Example Usage:
          member("someTextMember").text = getDisplayString(gvGameData, [#name, #score, #hits, #bullets])
          • 2. Re: Linear List
            Mister MUX Level 2
            Also, with this data structure you don't want to update data by specifying an index. Obviously the player at element 7 wont necessarily be the same after sorting. Assuming player names are unique, a handler such as this can be used to update a player's data. It returns true if the update suceeded, or false if an invalid player name was passed.
            on updatePlayerData gameData, playerName, dataList
              playerIndex = 0
                if gameData[x].name = playerName then
                  playerIndex = x
                  exit repeat
                end if
              end repeat
              if playerIndex = 0 then return false -- player name not found
              repeat with x = 1 to dataList.count
                gameData[playerIndex][dataList.getPropAt(x)] = dataList[x]
              end repeat
              return true -- player data was updated
            end
            Example usage:
            errorCode = updatePlayerData(gvGameData, "Player F", [#bullets:5,#score:99])
            • 3. Re: Linear List
              IEatSandvich Level 1
              Thanks, Mux. I'll see if i can get this to work, and let you know how it goes.
              • 4. Re: Linear List
                Mister MUX Level 2
                Well if you really want to stick with your original design, you can still use a bubble sort routine. You just have to manipulate each of the four lists individually.
                on updatescores
                  -- bubble sort
                  repeat with x = 1 to gvScoreList.count
                    repeat with y = 1 to gvScoreList.count - 1
                      if gvScoreList[y] < gvScoreList[y+1] then
                        -- sort the score list
                        temp = gvScoreList[y+1]
                        gvScoreList[y+1] = gvScoreList[y]
                        gvScoreList[y] = temp
                        -- sort the name list
                        temp = gvNameList[y+1]
                        gvNameList[y+1] = gvNameList[y]
                        gvNameList[y] = temp
                        -- sort the hits list
                        temp = gvHitsList[y+1]
                        gvHitsList[y+1] = gvHitsList[y]
                        gvHitsList[y] = temp
                        -- sort the bullets list
                        temp = gvBulletsList[y+1]
                        gvBulletsList[y+1] = gvBulletsList[y]
                        gvBulletsList[y] = temp
                      end if
                    end repeat
                  end repeat
                end
