4 Replies Latest reply on Aug 25, 2012 6:36 AM by Smal_7
    Flash builder 4.6 won't start. "An unexpected runtime error occured. No more handles."
    Smal_7
      Hello, I'm having a major issue with Flash Builder 4.6. Whenever I try to open it, an error pops up saying "An unexpected runtime error occured. No more handles."
      I got it off freeriatools.adobe.com, and the log file gives me the following errors :
      !SESSION 2012-04-25 20:40:19.812 -----------------------------------------------
      eclipse.buildId=I20100608-0911
      java.version=1.6.0_16
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments:  -os win32 -ws win32 -arch x86
      !ENTRY org.eclipse.ui 2 0 2012-04-25 20:40:36.702
      !MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
      !SUBENTRY 1 org.eclipse.ui 2 0 2012-04-25 20:40:36.702
      !MESSAGE Commands should really have a category: plug-in='com.qnx.flashbuilder.multiplatform.qnx.ui', id='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.OpenInfoCenter ', categoryId='com.qnx.flashbuilder.multiplatform.qnx.ui.commands.catego ry.help'
      !ENTRY org.eclipse.osgi 4 0 2012-04-25 20:40:37.412
      !MESSAGE An unexpected runtime error has occurred.
      !STACK 0
      org.eclipse.swt.SWTError: No more handles
          at org.eclipse.swt.SWT.error(SWT.java:4308)
          at org.eclipse.swt.SWT.error(SWT.java:4197)
          at org.eclipse.swt.SWT.error(SWT.java:4168)
          at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
          at org.eclipse.swt.widgets.TaskBar.createHandle(TaskBar.java:103)
          at org.eclipse.swt.widgets.TaskBar.<init>(TaskBar.java:96)
          at org.eclipse.swt.widgets.Display.getSystemTaskBar(Display.java:2564)
          at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.ge tTaskItem(Workbench.java:303)
          at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.ha ndleTaskBarProgressUpdated(Workbench.java:319)
          at org.eclipse.ui.internal.Workbench$TaskBarDelegatingProgressMontior.wo rked(Workbench.java:268)
          at org.eclipse.ui.internal.Workbench$StartupProgressBundleListener.bundl eChanged(Workbench.java:420)
          at org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEv ent(BundleContextImpl.java:847)
          at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventM anager.java:230)
          at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchr onous(ListenerQueue.java:148)
          at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent Privileged(Framework.java:1522)
          at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent (Framework.java:1458)
          at org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent (Framework.java:1453)
          at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(Bundl eHost.java:391)
          at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(Abstrac tBundle.java:299)
          at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java: 440)
          at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLo ader.java:268)
          at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFind LocalClass(EclipseLazyStarter.java:107)
          at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(C lasspathManager.java:462)
          at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalCla ss(DefaultClassLoader.java:216)
          at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLo ader.java:400)
          at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(Bundl eLoader.java:476)
          at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader. java:429)
          at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader. java:417)
          at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(De faultClassLoader.java:107)
          at java.lang.ClassLoader.loadClass(Unknown Source)
          at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader. java:345)
          at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleH ost.java:229)
          at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(Abs tractBundle.java:1207)
          at org.eclipse.equinox.internal.ds.model.ServiceComponent.createInstance (ServiceComponent.java:480)
          at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.createInst ance(ServiceComponentProp.java:271)
          at org.eclipse.equinox.internal.ds.model.ServiceComponentProp.build(Serv iceComponentProp.java:332)
          at org.eclipse.equinox.internal.ds.InstanceProcess.buildComponent(Instan ceProcess.java:588)
          at org.eclipse.equinox.internal.ds.ServiceReg.getService(ServiceReg.java :53)
          at org.eclipse.osgi.internal.serviceregistry.ServiceUse$1.run(ServiceUse .java:138)
          at java.security.AccessController.doPrivileged(Native Method)
          at org.eclipse.osgi.internal.serviceregistry.ServiceUse.getService(Servi ceUse.java:136)
          at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.get Service(ServiceRegistrationImpl.java:468)
          at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService( ServiceRegistry.java:467)
          at org.eclipse.osgi.framework.internal.core.BundleContextImpl.getService (BundleContextImpl.java:594)
          at org.osgi.util.tracker.ServiceTracker.addingService(ServiceTracker.jav a:450)
          at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(Service Tracker.java:980)
          at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(Service Tracker.java:1)
          at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.jav a:262)
          at org.osgi.util.tracker.AbstractTracked.trackInitial(AbstractTracked.ja va:185)
          at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:348)
          at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.java:283)
          at org.eclipse.core.internal.runtime.InternalPlatform.getBundleGroupProv iders(InternalPlatform.java:225)
          at org.eclipse.core.runtime.Platform.getBundleGroupProviders(Platform.ja va:1261)
          at org.eclipse.ui.internal.ide.IDEWorkbenchPlugin.getFeatureInfos(IDEWor kbenchPlugin.java:291)
          at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.makeFeatureDepende ntActions(WorkbenchActionBuilder.java:1217)
          at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.makeActions(Workbe nchActionBuilder.java:1026)
          at org.eclipse.ui.application.ActionBarAdvisor.fillActionBars(ActionBarA dvisor.java:147)
          at org.eclipse.ui.internal.ide.WorkbenchActionBuilder.fillActionBars(Wor kbenchActionBuilder.java:341)
          at org.eclipse.ui.internal.WorkbenchWindow.fillActionBars(WorkbenchWindo w.java:3564)
          at org.eclipse.ui.internal.WorkbenchWindow.<init>(WorkbenchWindow.java:4 19)
          at org.eclipse.ui.internal.tweaklets.Workbench3xImplementation.createWor kbenchWindow(Workbench3xImplementation.java:31)
          at org.eclipse.ui.internal.Workbench.newWorkbenchWindow(Workbench.java:1 920)
          at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:1918)
          at org.eclipse.ui.internal.Workbench$21.runWithException(Workbench.java: 1202)
          at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupT hreading.java:31)
          at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.ja va:135)
          at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4140)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3757)
          at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvi sor.java:803)
          at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java: 1595)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
          at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.ja va:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.jav a:667)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.flexbuilder.standalone.FlashBuilderApplication.start(FlashB uilderApplication.java:108)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandl e.java:196)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runAppli cation(EclipseAppLauncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ec lipseAppLauncher.java:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:344)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.ja va:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
          at java.lang.reflect.Method.invoke(Unknown Source)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
      !ENTRY org.eclipse.ui.workbench 4 0 2012-04-25 20:40:38.511
      !MESSAGE FrameworkEvent ERROR
      !STACK 0
      !ENTRY org.eclipse.osgi 4 0 2012-04-25 20:40:38.974
      !MESSAGE Application error
      !STACK 1
          at org.eclipse.ui.internal.WorkbenchWindow.createProgressIndicator(Workb enchWindow.java:3362)
          at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(Workben chWindow.java:1130)
          at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultConten ts(WorkbenchWindowConfigurer.java:623)
          at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContent s(WorkbenchWindowAdvisor.java:300)
          at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindo w.java:1036)
          at org.eclipse.jface.window.Window.create(Window.java:431)
          at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java: 1211)
      I was wondering if anyone has found a solution to this problem yet? Because I need this software to work on my laptop in order to start working on my school projects.. Thanks in advance.
      Oh yeah, OS : Windows 7 32bit
