1 Reply Latest reply on Apr 7, 2008 3:02 AM by Oliver Goldman
    Loading External XML File
      I'm stuck on something, i'm trying to load a xml file which is on my host. Basically i use that xml file for my data driven website, i'd like the same data to be used for my AIR application. How do i go about loading that file into my AIR application.
      I'm using Flash CS3.
      Also is there a way i could check the XML file on my host to see if it matches the data loaded? It kind of allows my application to see if the file has been changed and if so, update the information so it is up to date.
      Thanks in advance
