4 Replies Latest reply on Jun 26, 2012 8:19 AM by Jose Diego Diaz Cuellar
    Hiding a load clip.
    Jose Diego Diaz Cuellar Newcomer
      Hi to everyone, i'm working in a flash proyect using this action for each button/city (it's a map).
      btn_monteria.addEventListener(MouseEvent.CLICK, montpress)
      function montpress(Event:MouseEvent){
          //Crear una variable cargador para mostar el swf
          newMedia = new Loader;
          //Crear una variable para un clip vacio (anteriormente host)
          cont = new Sprite;
          //ruta para cargar la pelicula
          newMedia.load(new URLRequest("mapa_monteria.swf"));
          //mostar el boton cerrar
          btn_cerrar.visible = true;
          //Posicion x que va a tener el host
          cont.x = 10;
          cont.y = 120;
          stage.addChild(cont);
          stage.addChild(btn_cerrar);
          cont.addChild(newMedia);
      and in the top of the actions have this code to load the swf
      stop();
      btn_cerrar.visible = false;
      //Listener para cada una de las variables
      //Creacion de la variable cargador
      var newMedia:Loader;
      var cont:Sprite;
      //Listener y funciones para boton cerrar, asi como la visibilidad
      btn_cerrar.addEventListener(MouseEvent.CLICK, cerrar)
      function cerrar(Event:MouseEvent){
          cont.removeChild(newMedia);
          newMedia.unload();
          newMedia = null;
      As you can see works fine, but there is a little problem, if you press one city and then other city (with out pressing the close button) it doesn't hide the first city.
      It is a way for each time that press a button the other ones keep hiding????
      You can see it here
      Thanks ...
        • 1. Re: Hiding a load clip.
          _spoboyle Champion
              cerrar();
              newMedia = new Loader();
              cont = new Sprite();
              cont.x = 10;
              cont.y = 120;
          stop();
          var cont:Sprite;
          function cerrar(event:MouseEvent = null){
               if (cont.contains(newMedia))
               if (newMedia != null)
                   newMedia.unload();
              newMedia = null;
          • 2. Re: Hiding a load clip.
            Thanks for your reply .... it's not working .... here is the full code. Please tell me if i send you the .fla
            import flash.events.MouseEvent;
            import flash.display.Loader;
            import flash.display.Sprite;
            import flash.net.URLRequest;
            stop();
            var cont:Sprite;
                     newMedia.unload();
                newMedia = null;
            //Boton Monteria
                cont = new Sprite;
                cont.x = 10;
                cont.y = 120;
            //Boton Cucuta
            btn_cucuta.addEventListener(MouseEvent.CLICK, cucpress)
            function cucpress(Event:MouseEvent){
                cont = new Sprite;
                newMedia.load(new URLRequest("mapa_cucuta.swf"));
                cont.x = 10;
                cont.y = 120;
            //Boton Santa Marta
            btn_sta.addEventListener(MouseEvent.CLICK, stapress)
            function stapress(Event:MouseEvent){
                cont = new Sprite;
                newMedia.load(new URLRequest("mapa_sta.swf"));
                cont.x = 10;
                cont.y = 120;
            //Boton Villavicencio
            btn_vll.addEventListener(MouseEvent.CLICK, villpress)
            function villpress(Event:MouseEvent){
                cont = new Sprite;
                newMedia.load(new URLRequest("mapa_villavicencio.swf"));
                btn_cerrar.visible=true;
                cont.x = 10;
                cont.y = 120;
            //Boton Cartagena
            btn_ctg.addEventListener(MouseEvent.CLICK, ctgpress)
            function ctgpress(Event:MouseEvent){
                cont = new Sprite;
                newMedia.load(new URLRequest("mapa_cartagena.swf"));
                cont.x = 10;
                cont.y = 120;
            //Boton Bogota
            btn_bogota.addEventListener(MouseEvent.CLICK, bogpress)
            function bogpress(Event:MouseEvent){
                cont = new Sprite;
                newMedia.load(new URLRequest("mapa_bogota.swf"));
                cont.x = 10;
                cont.y = 120;
            //Boton Cali
            btn_cali.addEventListener(MouseEvent.CLICK, calipress)
            function calipress(Event:MouseEvent){
                cont = new Sprite;
                newMedia.load(new URLRequest("mapa_cali.swf"));
                cont.x = 10;
                cont.y = 120;
            //Boton Barranquilla
            btn_bll.addEventListener(MouseEvent.CLICK, bllpress)
            function bllpress(Event:MouseEvent){
                cont = new Sprite;
                newMedia.load(new URLRequest("mapa_barranquilla.swf"));
                cont.x = 10;
                cont.y = 120;
            //Boton Medellin
            btn_mdll.addEventListener(MouseEvent.CLICK, mllpress)
            function mllpress(Event:MouseEvent){
                cont = new Sprite;
                newMedia.load(new URLRequest("mapa_medellin.swf"));
                cont.x = 10;
                cont.y = 120;
            //Boton Dosquebradas
            btn_dq.addEventListener(MouseEvent.CLICK, dqpress)
            function dqpress(Event:MouseEvent){
                cont = new Sprite;
                newMedia.load(new URLRequest("mapa_dosquebradas.swf"));
                cont.x = 10;
                cont.y = 120;
            //Boton Ibague
            btn_ibague.addEventListener(MouseEvent.CLICK, ibgpress)
            function ibgpress(Event:MouseEvent){
                cont = new Sprite;
                newMedia.load(new URLRequest("mapa_ibague.swf"));
                cont.x = 10;
                cont.y = 120;
            //Boton Tunja
            btn_tunja.addEventListener(MouseEvent.CLICK, tunjapress)
            function tunjapress(Event:MouseEvent){
                cont = new Sprite;
                newMedia.load(new URLRequest("mapa_tunja.swf"));
                cont.x = 10;
                cont.y = 120;
            • 3. Re: Hiding a load clip.
              _spoboyle Champion
              you need to call cerrar() at the start of all your press functions i.e.
              montpress
              cucpress
              stapress
              villpress
              ctgpress
              bogpress
              calipress
              bllpress
              mllpress
              dqpress
              ibgpress and
              tunjapress
              • 4. Re: Hiding a load clip.
                Hi ... i was busy for a long time, so that's why i can't  uset it ...
                this is the function cerrar:
                         newMedia.unload();
                    newMedia = null;
                But how do i call it from each button??? ...
                Thanks a lot .... you can seet here how its working
