This content has been marked as final.
Show 2 replies
1. Re: Text With Outer Glow Does NOT Work as Part of a Slideshow...
bfento Apr 27, 2012 11:15 AM (in response to bfento)Well, I've created some new text and applied the same fx (outer glow) to it, and it works... Odd. I geuss the original text is somehow corrupted. I will report any further findings.
2. Re: Text With Outer Glow Does NOT Work as Part of a Slideshow...
bfento Apr 30, 2012 9:52 AM (in response to bfento)The outer glow only/image sequence combo only seems to be working if the text within the text frame is all the same size, leading, etc... The problematic text is on 3 lines, and each line has a different type size, leading, tracking, and some kerning. However, it works fine as part of an image sequence if all 3 lines have the same text attributes... Odd....
My solution was to convert it to outlines. Not ideal, but it works.
