3 Replies Latest reply on May 17, 2012 11:15 AM by sarahpeller
    Mysterious color application confusing me!
    sarahpeller
      Hello,
      I have just recieved an Indesign file from a client that I'd like to apply some edits to. The image consists of a couple of black and white images layered on top of each other. They only look semi-transparent in Indesign, although their Opacity is set to 100%. I have the linked files in my posession and they are solid black and white.
      Somehow, the old designer applied a color to these black and white images. I can't see where she might have done that. I'd like to be able to change the colors if need be.
      Anyone have any ideas?
      Sarah
        • 1. Re: Mysterious color application confusing me!
          Manish-Sharma Employee Moderator
          What is the Format of these images?
          Check if there is any effect applied to it ? , Go to Object-->Effects
          Indesign cannot edit the color of the imported images , like PSD , AI .... if these are the images which have been created in the Indesign then it's possible but you wrote you have the linked files hence I believe they are created in some other application and then imported in Indesign.
          Can you provide screen shot and the 2 sample images.
          • 2. Re: Mysterious color application confusing me!
            Not totally true. At least for black & white images or grayscale images ( e.g. TIFF) one could always apply a fill color.
            @Sarah – so select one of those images with the direct selection tool (the white arrow) and see if a color swatch is applied in the color swatches panel for fill.
            You also could set a black & white or grayscale image to "overprint". This might  also be the case.
            See this screenshot (German UI of InDesign CS5.5):
            A screenshot of the selected image could help. "Swatches" panel and "Attributes" panel open.
            Uwe
            • 3. Re: Mysterious color application confusing me!
              sarahpeller Level 1
              Thank you, Laubender. That is exactly what I was looking for! Easy fix!
