3 Replies Latest reply on Apr 29, 2012 6:15 AM by Steve Grisetti
    Starting Over
    Randall Renn
      Newby trying to start over.
      I'm trying to download my existing Catalog (~11 Gb).  I'm trying to get all of my computer's file in a more organized fashion before reloading into the online catalog. I think I now understand the Catalog/Album relationship.
      Near the end of each successive attempt. I've  encountered:
      "Backup/Sync may have encountered some issues in the last cycle. Please check for warnings in Elements Organizer."
             and
      "Runtime Error!  Program: ...dobe\Elements 9 Organizer\ElementsOrganizerSync\Agent.exe   abnormal program termination"
      Thanks for any help!  Signed "Ball in High Weeds" - Randall
        • 1. Re: Starting Over
          What operating system are your running? 64-bit or 32-bit?
          How fast is your processor, how much RAM do you have and how much free, clean, freshly defragmented free space is on your hard drive?
          Are you working with only one hard drive? If not, how is your second drive attached.
          Also, you say you're "starting over". Does this mean that you've already had the programs installed once and that they used to work?
          Any other details you can provide might be helfpul.
          • 2. Re: Starting Over
            Randall Renn Level 1
            Steve,
            I'll  try my best to explain my current situation.
            Q1.  What operating system are your running? 64-bit or 32-bit?
            A1.  The following is displayed by running winver:
            "Windows XP Professional"
            Versin 5.1 (Build 2600.xpsp_spp3_gdr.111025-1629 : Service Pack 3)
            Copyright 2007 Microsoft Corporation
            Physical memory available to Windows:  1,046,620 KB
            Q2.  How  fast is your processor, how much RAM do you have and how much free,
            clean, freshly de-fragmented free space is on your hard drive?
            A2.  From msinfo32, the following:
            OS Name    Microsoft Windows XP Professional
            Version    5.1.2600 Service Pack 3 Build 2600
            OS Manufacturer    Microsoft Corporation
            System Name    DELL-8400
            System Manufacturer    Dell Inc.
            System Model    Dimension 8400
            System Type    X86-based PC
            Processor    x86 Family 15 Model 3 Stepping 4 GenuineIntel ~3192 Mhz
            BIOS Version/Date    Dell Inc. A03, 10/11/2004
            SMBIOS Version    2.3
            Windows Directory    C:\windows
            System Directory    C:\windows\system32
            Boot Device    \Device\HarddiskVolume1
            Locale    United States
            Hardware Abstraction Layer    Version = "5.1.2600.5512 (xpsp.080413-2111)"
            User Name    DELL-8400\Randall
            Time Zone    Eastern Daylight Time
            Total Physical Memory    1,024.00 MB
            Available Physical Memory    509.31 MB
            Total Virtual Memory    2.00 GB
            Available Virtual Memory    1.96 GB
            Page File Space    3.90 GB
            Page File    C:\pagefile.sys
            Q3.  Are you working with only one hard drive? If not, how is your second drive
            attached.
            C: -->
            Type:  Local Drive
            File system: NFTS
            Used space:  42,895,507,456 bytes (39.9 GB)
            Free space:  46,233,591,808 bytes (43.0 GB)
            Capacity: 89,129,099.264 bytes  (83.0 GB)
            d:  -->  DataPartition
            Type:  Local Drive
            File system: NFTS
            Used space:  8,277,123,072 bytes (7.70 GB)
            Free space:  62,624,755,712 bytes (58.3 GB)
            Capacity: 70,901,878,784 bytes  (66.0 GB)
            l:  -->  HP SimpleSave (HP External Hard Drive (320 GB)
            Type:  Local Drive
            File system: NFTS
            Used space:  211,143,647,232 bytes (196 GB)
            Free space:  108,225,335,296 bytes (100 GB)
            Capacity: 319,368,982,528 bytes  (297.0 GB)
            m: -->PhotoShop  (Western Digital external hard drive)
            Type:  Local Drive
            File system: NFTS
            Used space:  12,239,351,808 bytes (11.3 GB)
            Free space:  66,402,549,760 bytes (61.8 GB)
            Capacity: 78,641,901,568 bytes  (73.2 GB)
            Q4.  Also,  you say you're "starting over". Does this mean that you've already
            I have an active account "renn@bellsouth.net"  PW "r7e3n6n6"
            I started uploading files to my 20GB account not understanding the linkage
            between the local files and on-line files.  The files were poorly organized on
            my end and generically named.  I was using the larger external hard drive for
            all of my locally stored pictures.
            Q5. Any other details you can provide might be helpful.
            Due to a traumatic brain injury (anoxic heart attack) on 09-04-2007, my memory,
            planning and organization skills have been dramatically affected (but
            improving). I do not fully understand the "catalog, album, project"
            relationships.  I now know that I have one catalog and should use projects to
            create an album.  I decided (probably wrongly)  to make my small ("m") external
            drive my Photoshop repository.  I've tried to back-up everything on-line to my
            hard drive, then clean-up, defrag, re-arrange and relocate everything locally.
            Then rebuild the on-line catalog to the new location by syncing from the back-up
            catalog.
            When my attempt to re-sync (~20,000) files failed near the end of the syncing
            process.  I thought when I got the back-up re-synced to their final destination,
            I could work on naming conventions over time as a created new or finalized my
            existing "albums".
            You now know why I referred to my situation as "starting over" and "in high
            weeds".  I want to eventually prepare presentations for special events for my
            elderly relatives as my second career.  I worked for 30 years in
            telecommunications (planning and engineering) before my career ending life event
            in 2007. I'm retired on disability.
            Thanks in advance,  Randall Renn
            • 3. Re: Starting Over
              I may not be able to be of much help, but a few issues stick out.
              1) This appears to be a Pentium 4 3 ghz computer with 1 gigabyte of RAM, which are fairly minimal specs for running this program. In fact, if it's true that you've only got 1 gig of RAM, you're likely not going to be able to run this program at all with any real success. I would never run this program with less than 4 gigs of RAM. And I would never attempt to edit hi-def video on a Pentium.
              2) You haven't said but it's also pretty likely your computer is full tmp files, fragmentation and possibly spyware. I'd recommend you run a program like Advanced System Care Free's Deep Care to clean things up and boost your performance. You can get it from http://www.iobit.com/advancedsystemcareper.html
              3) I'm still not clear if you've had a working catalog before or not. But clearing out the old catalog may give the computer a chance to rebuild it, which could help you get around corruptions that may have snuck in. The FAQs to the right of this forum offer suggestions for rebuidling your Organizer catalog.
              http://forums.adobe.com/thread/390603
