1 Reply Latest reply on Apr 28, 2012 3:32 PM by Jim_Simon
    Having trouble exporting file from After Effects CS5.5
      I am trying to add some titles to a Multi Camera mix I have finished. I have exported my multi cam that I created in Premiere Pro as an MPEG.
      So hears what I have done:
      - open After effects
      - create new composition (HD 1080x1440- length 2:16 (so clip fits)
      - I place my clip in the time line the type some text.
      - in the effects bar I click the roll up and select "Browse Presets" which opens adobe bridge
      - I apply my effects and they play back in elements fine...
      When I try to export my clip as a Premiere Pro Project it doesnt keep my animated txt when I open it. Says it does not support the presets. his
      Con someone please help me export this project? Getting very frustrating. I need it as a High Res HD file
        • 1. Re: Having trouble exporting file from After Effects CS5.5
          Jim_Simon Level 8
          Create the titles in After Effects without the MPEG.  (Or if you must use it as a reference, go ahead and do so, and then when you're done creating the title, delete the MPEG.)
          Then go back to PP and select File>Dynamic Link>Import After Effects Composition...  Navigate to the AE project that has the title, and bring in that composition.  It will appear in your bin as a clip.  Then you add it to the sequence and export the completed video with titles.
