0 Replies Latest reply on Apr 29, 2012 9:42 AM by mofqr
    SQLite Database and TLF Text in Flash CS5
    mofqr
      I encountered the following problem when working with the built-in sqlite database and using TLF TextFields in Flash CS5
      When I tried to use TLF TextFields alone, I don't face any probelem,
      but when I start using a database connectivity code, the TLF TextFields placed on the stage are not shown, but instead, the SWF file is showing the built-in preloader with five dots looping.
      I tried changing the default Linkage in ActionScript 3 Settings to Merge Mode, but in this case nothing is shown, not the textfields, neither the preloader.
      I think the problem is related to loading the TLF Text Engine, but I couldn't figure out what to do.
      The following is my code placed in first frame:
      import flash.data.SQLConnection;
      import flash.events.SQLErrorEvent;
      import flash.events.SQLEvent;
      import flash.filesystem.File;
      var conn:SQLConnection = new SQLConnection();
      conn.addEventListener(SQLEvent.OPEN, openHandler);
      conn.addEventListener(SQLErrorEvent.ERROR, errorHandler);
      // The database file is in the application directory
      var folder:File = File.applicationDirectory;
      var dbFile:File = folder.resolvePath("DBSample.db");
      conn.openAsync(dbFile);
      function openHandler(event:SQLEvent):void
          trace("the database was created successfully");
      function errorHandler(event:SQLErrorEvent):void
          trace("Error message:", event.error.message);
          trace("Details:", event.error.details);
      stop();
      and I am using one TLF TextField on the stage for later use.
      Publish Settings>> Player: AIR 2.6
      and not to forget, when I test the file using Contol Panel >> Test in Air Debug Launcher (Desktop), the file is working correctly.
      but when I open the generated SWF file, the problem appears.
      I hope that I find some help
      Thanks.
