• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Acrobat Pro 10.1.3 is crashing when trying to open it in an application a second time
New Here ,
Apr 30, 2012 Apr 30, 2012
My Acrobat Pro 10.1.3 is crashing when trying to open it in an application a second time. Please find the error details below
Problem signature:
  Problem Event Name:    APPCRASH
  Application Name:    Acrobat.exe
  Application Version:    10.1.3.23
  Application Timestamp:    4f7bc871
  Fault Module Name:    Acrobat.dll
  Fault Module Version:    10.1.3.23
  Fault Module Timestamp:    4f7bd9b8
  Exception Code:    c0000005
  Exception Offset:    000d61eb
  OS Version:    6.1.7600.2.0.0.256.48
  Locale ID:    1033
  Additional Information 1:    0a9e
  Additional Information 2:    0a9e372d3b4ad19135b953a78882e789
  Additional Information 3:    0a9e
  Additional Information 4:    0a9e372d3b4ad19135b953a78882e789
The issue started after updating from Adobe Acrobat Pro X to Acrobat 10.1.2. Please note that this happens in Windows 7
The RPC server is unavailable. (Exception from HRESULT: 0x800706BA) is the error that is thrown back by the acrobat.exe
Any directions to how to solve this issue will be largly appreciated.
TOPICS
Acrobat SDK and JavaScript
Views
26.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Start by making sure all 3rd party plugins are removed.
Votes
Translate
Translate
Report
Report
New Here ,
May 01, 2012 May 01, 2012
I havent installed any thiry party plugins for acrobat. But is there any way to view the third party plugs from acrobat? I checked in control panel but didnt find any
Can you please let me know what else should I check
Votes
Translate
Translate
Report
Report
New Here ,
May 03, 2012 May 03, 2012
Can you please let me know why this issue is happening from the information given in the problem signature. The issue was not there with AcrobatX base version.
Can you please let me know what changed with the 10.1.2 update
Votes
Translate
Translate
Report
Report
New Here ,
May 08, 2012 May 08, 2012
Currently in certified mode - yes in my adobe. So that rules out the third party plugin issue
Votes
Translate
Translate
Report
Report
Kindly create and share the crash dump next time you see a crash.
Steps to create Crash Dump:
1) As soon as Acrobat crashes, open Task Manager.
2) Go to Processes tab and select Acrobat.exe process.
3) Right Click on the Acrobat process and select Create Dump File.
4) Compress and share the dump file created via some file sharing server.
Votes
Translate
Translate
Report
Report
New Here ,
Please find the dump in the below link
https://docs.google.com/open?id=0B6LT6FMgZB_UM04xMFV2OGRTMzg
Votes
Translate
Translate
Report
Report
New Here ,
May 09, 2012 May 09, 2012
Hi vamalik,
Please let me know if I you were able to download the dump file. I have compressed the file in .rar format
Votes
Translate
Translate
Report
Report
May 10, 2012 May 10, 2012
Hi VKP1,
I had downloaded the file without any problem.
The issue is currently under investigation.
Votes
Translate
Translate
Report
Report
New Here ,
May 14, 2012 May 14, 2012
Hi Vamalik,
Thanks alot for looking into this.
Votes
Translate
Translate
Report
Report
New Here ,
May 16, 2012 May 16, 2012
Hi Vamalik,
Where you able to find the cause of this issue. This is an issue that is highly escalated by our customers and any help will be highly appreciated
Vidhya
Votes
Translate
Translate
Report
Report
May 17, 2012 May 17, 2012
Hi VKP1,
The issue is still under investigation.
Meanwhile, I want to confirm the exact steps to reproduce the issue. The crash occurs when you -
a) open a pdf file in Acrobat, close it and again open a pdf.
or
b) open a pdf file in Acrobat and then open another pdf
And you have seen this issue since your Acrobat was updated to 10.1.2. Before that there was no problem. Right?
Votes
Translate
Translate
Report
Report
New Here ,
The issue happens in case a. ie when I open the pdf in an application, close it and open it again. yes, This issue was not there before updating to 10.1.2
Votes
Translate
Translate
Report
Report
May 18, 2012 May 18, 2012
Hi VKP1,
Such basic scenario should not crash. These things are thoroughly tested.
Therefore I believe something is wrong with your Acrobat installation.
Try repairing your Acrobat from Control Panel->Programs or Uninstall and Reinstall it. (Make sure you have "Full Access" permissions on your installation directory.)
Votes
Translate
Translate
Report
Report
New Here ,
May 21, 2012 May 21, 2012
This issue happens only after I updated to 10.1.2. Did you get any hint from the dump file provided
More over, this is not happening on acrobat interface. But trying to open it inside an external application
Votes
Translate
Translate
Report
Report
May 24, 2012 May 24, 2012
Hi VKP1,
The steps you mentioned are very basic and always thoroughly tested. Hence I was not able to reproduce the issue at my end.
But as you have now said that this is happening only in some external application and not in Acrobat, one thing we can be sure of is that the problem lies in way this external application is handling Acrobat.
Which application is this and how are you opening pdf in it?
Votes
Translate
Translate
Report
Report
New Here ,
May 28, 2012 May 28, 2012
Hi vamalik,
We are opening  pdf inside a window's Group Box control using
oAVDoc.OpenInWindowEx(pDFPath, hwnd.ToInt32(),,1, 1, 0, 1, 2, 0, 0, 0)
The pdf is openeing when we load for the first time.
Second time it is throwing error.
This was working finr from Acrobat 7 till 10.1. This error started happening after the acrobat was updated to 10.1.2
We can prevent this from happening in 10.1.2 by killing the acrobat process. But this will stop all the acrobat opened outside the application
Please advise
Votes
Translate
Translate
Report
Report
New Here ,
Jun 01, 2012 Jun 01, 2012
I am also experiencing this repeated APPCRASH, under different circumstance: after I open an existing pdf and then try to add pages after from my scanner. As the previous poster stated, this problem only started to occur after 10.1.2 update.  I can reproduce this error at will. No other app is open on the desktop. I have used the repair installation feature several times on my Win7 Ultimate 64 desktop PC (which reports NO other issues or crashed except for Acrobat).
Problem signature:
Exception Offset: 00212f27
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Read our privacy statement online:
Process File      : Acrobat.exe
Event Name        : Stopped working
Event Time        : 5/31/2012 9:19:53 AM
User Name         : Bruce Ades
Exception Code    : 0xc0000005
Exception Offset  : 0x00212f27
Fault Module Name : Acrobat.dll
Process Path      : G:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Acrobat.exe
Report File Size  : 23,452
Report File Path  : C:\Users\Bruce Ades\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_Acrobat.exe_12b3ee9094c52bbc526a25ffdc491d578263835_1034ae88\Report.wer
Votes
Translate
Translate
Report
Report
Jun 04, 2012 Jun 04, 2012
Hi Futhermucker,
Votes
Translate
Translate
Report
Report
New Here ,
I lost or accidently deleted the dump. Will recreate and send up as you
asked!
Votes
Translate
Translate
Report
Report
New Here ,
Jun 25, 2012 Jun 25, 2012
Hi
Here it is. Crashed while trying to append an existing Acrobat file with a new doc scan.
Only 7 days to download from now. Help appreciated. I had no idea these dmp files
were so big.  FYI: I have MS Visual Studio Debugger and it could not debug the crash.
http://wikisend.com/download/928000/Acrobat Crash Dump File.zipx
FM
Votes
Translate
Translate
Report
Report
Guest
Mar 05, 2013 Mar 05, 2013
LATEST
Has a resolution to this issue ever been found.  We are using 10.1.5 and if users open mulitply PDF's and close them we get an error every time and can not find a way to stop it.  The error in the event view is the same that has been posted above and we have not found a resolution.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 05, 2012 Jun 05, 2012
Hi vamalik,
Please let me know if you need anything else from my side. When can we expect next version of acrobat? Is there any way to fix this issue in 10.1.3 itself?
Vidhya
Votes
Translate
Translate
Report
Report
Participant ,
Aug 02, 2012 Aug 02, 2012
I am getting an error as well... running Acrobat 10.1.3 on Windows 64bit machine. I also am repeatedly getting the Adobe Sofware License Agreement and I can't get it to stop showing up. I tried repairing my installation but to no avail... please help. If I click on the dump file as soon as Acrobat crashes it will not let me copy it saying the handle is invalid. The process actually gets shut down... over and over and over and over. I will click accept on the Agreement and it opens up Acrobat then it recycles - shuts me down then opens it up again. Please help!
Votes
Translate
Translate
Report
Report
New Here ,
Sep 07, 2012 Sep 07, 2012
If you are useing firefox, try to paste the link into another in browser, This had worked for me on PC, and mac.
PC user's  Also try admin setting on the program, or mabe run in vista or XP.
Votes
Translate
Translate
Report
Report
