1 Reply Latest reply on May 1, 2012 1:01 PM by Ida Eve
    End user image insert field
    Mike603
      Hello,
      I need to create a template that includes areas for the end user to insert photos if needed. If not needed I would like the image box to not be visible and the text to adjust accordingly. Can anyone help?
      Thank you in advance!
        • 1. Re: End user image insert field
          Ida Eve Level 2
          I would create a subform with the "Image Field".  Set the presence of that subform to hidden.  Add a Checkbox to your form, "add image". When the check box is selected, it will display the subform where users can add an image.
          Use this code on the checkbox - Change Event - JavaScript
          if
          (this.rawValue==1)
              {subformName.presence="visible"}
          else
              {subformName.presence="hidden"}
          Use the same code in the Inialized Event.  This will save the state of the form after they fill it out and save it.
