• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
2
Document opens in print mode
Participant ,
May 01, 2012 May 01, 2012
I have downloaded a few pdfs from a site I pay to access.  I can't attach an example here.  We are allowed to post them for our staff to read, but the only way I can download is to print them to a pdf.
When I save the file and try to open it, it automatically opens the print dialog box.
The document is not protected and I can change the properties on it.
How can I have this open as a plain old pdf and not with the print dialog box open?
Thank you
TOPICS
Create PDFs
Views
69.5K
Translate
Translate
Report
Report
Community guidelines
community guidelines
correct answers 2 Correct answers
Community Expert , May 01, 2012 May 01, 2012
There's probably a script embedded in it that is causing it.
The easiest way to confirm that would be to disable JS from the preferences
of Acrobat and then try to open the file.
Votes
Translate
Translate
New Here , Oct 25, 2023 Oct 25, 2023
1. click on the pdf file and open it with Google Chrome.
2. print it as pdf and name it differently
3. problem solved!
Votes
Translate
Translate
Community Expert ,
Votes
Translate
Translate
Report
Report
Participant ,
Wow, that was a fast answer.
OK, so that fixed the problem for me, but is there a way to remove the embedded script so it won't open in print mode for other users?
Thanks again.
Votes
Translate
Translate
Report
Report
Community Expert ,
Yes, you can remove it by going to Tools - Java - Document JavaScripts and
delete it from there. This is assuming that the file has not been protected
against modifying it, of course.
Votes
Translate
Translate
Report
Report
Participant ,
Hmm, I'm using Acrobat 9 and I don't see that setting.
I did find Advanced > PDF Optimizer > Discard Objects and selected both Discard all JavaScript actions and Discard embedded print settings.
When I click OK I get Conversion Warnings > An error was encountered while processing images.
If I go to File Properties the Security Method says No Security and everything is set to Allowed.
You've been very helpful, any other suggestions?
Votes
Translate
Translate
Report
Report
Community Expert ,
In that version it will be under Advanced - Document Processing - Document
JavaScripts.
Votes
Translate
Translate
Report
Report
Participant ,
OK, I found that, but there aren't any JavaScripts listed to delete.
I checked a couple other of these documents and it's the same thing, they open with the Print Dialog box, but there aren't any JavaScripts listed.
Votes
Translate
Translate
Report
Report
Community Expert ,
Another option could be that it was embedded into the PageOpen action of
the first page. Open the Pages panel, right-click the first page and select
Page Properties. Go to the Actions tab and check if there's a PageOpen
action defined there. If so, delete it.
Votes
Translate
Translate
Report
Report
Participant ,
Nope, no actions.
Votes
Translate
Translate
Report
Report
Community Expert ,
Without seeing the file, I don't have any other ideas for you at the
moment. But yes, "re-frying" the file (printing it to the PDF printer),
should get rid of it.
Votes
Translate
Translate
Report
Report
Participant ,
While not ideal, a poormans work around is to reprint it to a pdf.
Votes
Translate
Translate
Report
Report
New Here ,
Jun 06, 2023 Jun 06, 2023
I could not find preferences etc but rather just printed the problem file as "adobe PDF",  The newly created .pdf file did not replicate the print dialogue box and also had the page slider restored to the right, which seems connected to this problem.
Votes
Translate
Translate
Report
Report
New Here ,
3. problem solved!
Votes
Translate
Translate
Report
Report
New Here ,
Feb 29, 2024 Feb 29, 2024
LATEST
Funny that this goes back to 2012!  Just happend to me with a file sent to me for review.  Opening in any method (using Acrobat X Pro) forces open the print dialog.  In the Tools interface I selected "Protection" then "Remove Hidden Information."  Among the choices was "Links, actions and javascripts."  I unchecked all but the "Links, actions and javascripts" option, removed it, then saved the file.  All better.  This particular document did not have any embedded links so I can't say whether or not my action would have adversely affected other document properties.
Votes
Translate
Translate
Report
Report
