11 Replies Latest reply on Aug 28, 2017 1:23 AM by Laubender
    Fit Text Frame to Content - Applescript
    ax1e2l_b3r4a5s6s Level 1
      I'm trying to size a text frame to fit the width of it's contents.
      Possible??
        • 1. Re: Fit Text Frame to Content - Applescript
          Muppet Mark Level 5
          tell application "Adobe InDesign CS5"
               tell the active document
                    tell the first text frame
                         fit given frame to content
                    end tell
               end tell
          end tell
          • 2. Re: Fit Text Frame to Content - Applescript
            Thank you.
            I know the name of the text frame, so I try:
            tell application "Adobe InDesign CS5.5"
                                tell the text frame PersonalizeOneT
                                end tell
                      end tell
            end tell
            This doesn't work.
            Undeclared variable.
            Sorry for the stupid questions.  Applescript syntax confuses the heck out this old php programmer !
            • 3. Re: Fit Text Frame to Content - Applescript
              Muppet Mark Level 5
              The green color indicates a script variable… as you have not previously set/declaired it… it's not vaild… If it's some sting property then wrap it in double quotes for AppleScript… eg
                                          set Text_Frame to the first text frame whose label is "test"
                                          tell Text_Frame to fit given frame to content
                           end tell
              end tell
              • 4. Re: Fit Text Frame to Content - Applescript
                Larry G. Schneider Adobe Community Professional & MVP
                Try putting the name of the text frame in quotes.
                • 5. Re: Fit Text Frame to Content - Applescript
                  Mark -
                  We are getting closer:
                    set Text_Frame to the text frame "PH"
                    end tell
                  end tell
                  works, but it only fits the frame to the height, not the width.
                  Frame contains three lines of text, all centered.
                  Any more thoughts???
                  • 6. Re: Fit Text Frame to Content - Applescript
                    sstanleyau Level 4
                    Which is exactly what the command does in the UI -- that's how it works. If you want it reduced in width, you will have to get the length of each line, find the longest, and set the width to that.
                    • 7. Re: Fit Text Frame to Content - Applescript
                      -hans- Level 4
                      Shane's right ;-)
                      Getting it from the left:
                              set Text_Frame to item 1 of (every text frame whose label is "PH")
                              tell Text_Frame
                                  set theLines to every line
                                  --get maxLineLength
                                  set maxLength to null
                                  repeat with i from 1 to count of theLines
                                      set {start, stopp} to {horizontal offset of line i, end horizontal offset of line i}
                                      set currentLineLength to stopp - start
                                      if i is 1 then
                                          set maxLength to currentLineLength
                                      else
                                          if currentLineLength is greater than maxLength then
                                          end if
                                      end if
                                  end repeat
                                  --set x2-bounds of Text_Frame
                                  set {y1, x1, y2, x2} to visible bounds
                                  set visible bounds to {y1, x1, y2, x1 + maxLength}
                                  --fit height
                              end tell
                          end tell
                      end tell
                      Hope it'll work
                      Hans-Gerd Claßen
                      • 8. Re: Fit Text Frame to Content - Applescript
                        Great!  Thank you!
                        • 9. Re: Fit Text Frame to Content - Applescript
                          sstanleyau Level 4
                          Hope it'll work
                          It will nearly all the time, but it's worth a check afterwards to make sure. It can fail if, for example, the last text on the longest line is a long auto page number; InDesign gives the wrong width for those.
                          Also, it's a fraction quicker to say:
                                  set Text_Frame to (text frame 1 whose label is "PH")
                          rather than:
                          • 10. Re: Fit Text Frame to Content - Applescript
                            alexandrel16871950 Level 1
                            Hey! I'm trying to make the following command with illustrator however it's not recognize:
                            Any workaround would be very much appreciated?
                            Thanks!
                            • 11. Re: Fit Text Frame to Content - Applescript
                              Hi Alexandre,
                              you asked in the InDesign Scripting Forum.
                              For Adobe Illustrator scripting see here:
                              Illustrator Scripting
                              Regards,
                              Uwe
