5 Replies Latest reply on Apr 7, 2008 9:39 AM by Captiv8r
    Help popup not in a browser
    JustJump Level 1
      When I build a WebHelp project, I then link my app to the main .htm file. This of course opens in a browser. I notice when in RoboHelp, if I open their help, it's still opening a .htm frameset but it's not launching in a browser. How can I accomplish this?
      The issue with the browser is that if it's opening a local .htm (C:\Help\MyHelp.htm), it brings up that infamous yellow bar asking if you want to allow blocked content and I don't want the users to get that.
      Thanks in advance!
      ~ Lisa
        • 1. Re: Help popup not in a browser
          Hi Lisa and welcome to our community
          To banish the pesky Yellow Information Bar, you need to enable MOTW (Mark Of The Web). This is normally done using the intermediate dialogs you see when you generate WebHelp by double-clicking the WebHelp layout in the Single Source Layouts area.
          The Help you are seeing with RoboHelp is opening via the WebHelp API. Basically, this is just an external JavaScript file that causes the window to display with none of the typical chrome elements, such as the Address bar, Status bar, Toolbar, etc..
          Cheers... Rick
          • 2. Re: Help popup not in a browser
            JustJump Level 1
            Not sure I understand this. Can you explain a bit further?
            I am trying the JS Solution but I assume it has to be used in conjunction with what you have above. Thanks again!
            • 3. Re: Help popup not in a browser
              JustJump Level 1
              I found the option. Thank you so much!
              • 4. Re: Help popup not in a browser
                Hi again Lisa
                Let's back up a tad. There are many ways to generate your WebHelp.
                * You may click the "Quick Generate" toolbar icon
                * You may use the super secret "now that I''ve told you I have to kill you" keyboard combination of Ctrl+M
                * You may click File > Generate Primary Layout
                * You may expand the Single Source Layouts pseudo folder and double-click the layout.
                If you use the last option, you should see some intermediate screens that allow you to choose many different options prior to creating your help. The first screen should have a check box labeled "Add Mark of the Web". This is where you should find the option.
                Cheers... Rick
                • 5. Re: Help popup not in a browser
                  LOL, just after posting the steps I see you found the option!
                  Good on ya... Rick
