2 Replies Latest reply on May 2, 2012 7:16 PM by Reald__
    big trouble! every message to BlaseDS has a memory leak of string
    Reald__
      i'm confussing on this for month, need a handsome anyone help and with great thanks.
      trouble is this:
      1.i useed RemoteObject to call a function on java every 0.05 second, the memory will leave a string can't free per call, string like this: "6FC75E07-D8B6-785B-183F-0B93CE990", every id is Message id as i know, i saw them in profile analysis. whatever simple baseic function i wrote, it happened this wrong the same, even the helloworld function without a hello world print just a simple return.
      detail like this:
      1.on my test, i configed a java web project on tomcat6, and configed a BlaseDS in it.
      2.i set a function just name it as helloworld, and write just a return in java project;
      3.i set a simple RemoteObject object and a timer run it every 50ms.
      4.i run it on profile and saw the question.
      flash bulder code:
      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
              xmlns:mx="library://ns.adobe.com/flex/mx" creationComplete="exe()">
      <fx:Script>
        <![CDATA[
         import mx.messaging.messages.RemotingMessage;
         import mx.rpc.events.FaultEvent;
         import mx.rpc.events.ResultEvent;
         private var serverRemoteDestination  :  String  = "facilitiesBiz";
         private var remoteObjectGetFacility  :  RemoteObject  =  new RemoteObject();
         public function exe():void{
          remoteObjectGetFacility.endpoint = "http://localhost:8080/NewM/messagebroker/amf";
          remoteObjectGetFacility.destination  =  serverRemoteDestination;
          var timer:Timer=new Timer(50);
          timer.start();
          timer.addEventListener(TimerEvent.TIMER,gogo);
          function gogo(e:TimerEvent):void{
           tabRemotor.getOperation("testing").send();
      //     remoteObjectGetFacility.getOperation("getFacilities").send("admin","admin");
          if(!tabRemotor.hasEventListener(ResultEvent.RESULT)){
           tabRemotor.addEventListener(ResultEvent.RESULT, remoteResultFunc);
           tabRemotor.addEventListener(FaultEvent.FAULT, remoteFault);
          function remoteResultFunc(e  :  ResultEvent)  :  void
           //    remoteObjectGetFacility.removeEventListener(ResultEvent.RESULT, remoteResultFunc);
           //    remoteObjectGetFacility.removeEventListener(FaultEvent.FAULT, remoteFault);
           //    remoteObjectGetFacility.getOperation("getFacilities").clearResult();
           //    remoteObjectGetFacility.getOperation("getFacilities").cancel();
           //    remoteObjectGetFacility.channelSet.logout();
           //    remoteObjectGetFacility.disconnect();
      //     trace("one processed");
           //    remoteObjectGetFacility.logout();
          function remoteFault(e  :  FaultEvent)  :  void
           trace("error");
      </fx:Script>
      <fx:Declarations>
        <!-- 将非可视元素(例如服务、值对象)放在此处 -->
        <s:RemoteObject endpoint="http://localhost:8080/NewM/messagebroker/amf" destination="facilitiesBiz" id="tabRemotor">
         <s:method name="testing"/>
        </s:RemoteObject>
      </fx:Declarations>
      </s:WindowedApplication>
