0 Replies Latest reply on May 2, 2012 1:05 PM by tyuiop86
    Custom attribute in a custom component never gets set up
    tyuiop86
      I created a custom numericStepper extending Spark numericStepper, code below:
      package view.component.controls
                import flash.events.FocusEvent;
                import flash.events.MouseEvent;
                import spark.components.NumericStepper;
                public class CustomNumericStepper extends NumericStepper
                public var preventKeyDown:Boolean=false;
                public function CustomNumericStepper ()
                                                   super();
                                    override protected function focusInHandler(event:FocusEvent):void
                                                   super.focusInHandler(event);
                                                   if(this.textDisplay.text == "0")
        this.textDisplay.text = "";
                                    override protected function childrenCreated():void
                                                   super.childrenCreated();
                                                   this.textDisplay.restrict="0-9";
                                    override protected function system_mouseWheelHandler(event:MouseEvent):void
                                                   event.preventDefault();
                                                   super.system_mouseWheelHandler(event);
                    override protected function keyDownHandler(event:KeyboardEvent):void
                                                   if(preventKeyDown)
                                                   else
        super.keyDownHandler(event);
      The problem that I'm having is that the preventKeyDown attribute never gets the value set up in the MXML where I use this custom numeric stepper. I'm using it in an itemRenderer inside a DataGrid. Code below:
      <mx:DataGridColumn headerText="{resourceManager.getString('Template', 'Qty')}"  width="80" editorDataField="value" dataField="Quantity"
        textAlign="center" visible="{hasPermission(UserProxy.ORDER_TEMPLATES, UserProxy.UPDATE)}">
        <mx:itemRenderer>
        <fx:Component>
        <mx:HBox paddingLeft="5" paddingRight="5" horizontalAlign="center">
        <fx:Script>
        <![CDATA[
        import model.UserProxy;
        import mx.controls.listClasses.IListItemRenderer;
        import mx.resources.ResourceManager;
        import view.component.controls.IBSADataGrid;
        override public function set data(value:Object):void
        super.data = value;
        if(data)
        if(data.IsObsoleteItem.t oString() == "true")
        txtQty.enabled = false;
        txtQty.setStyle('co ntentBackgroundColor', '#aaaaaa');
        this.toolTip = ResourceManager.getInstance().getString('Template', 'tooltip_obsolete');
        else if(!outerDocument.hasPermission(UserProxy.ALLOW_RESTRICTED, UserProxy.SEE_RESTRICTED_PRODUCTS) && data.Product.IsAdminData.toString() ==        "true")
        this.toolTip = ResourceManager.getInstance().getString('Template', 'tooltip_admin_data');
        else
        txtQty.enabled = true;
        txtQty.setStyle('co ntentBackgroundColor', 'white');
        protected function txtQty_keyFocusChangeHandler(event:FocusEvent):void
        var templateDetailsGrid:IBSADataGrid = this.owner as IBSADataGrid;
        var index:int = templateDetailsGrid.itemRendererToIndex(this as IListItemRenderer);
        var nextFocusComponent:Object;
        var colIndex:int;
        if(outerDocument.dgColTemplat eID.visible)
        colIndex = 3;
        else
        colIndex = 4;
        if(event.shiftKey)
        nextFocusComponent = templateDetailsGrid.indexToItemRendererAtColumn(index-1, templateDetailsGrid.columnCount-colIndex);
        else
        nextFocusComponent = templateDetailsGrid.indexToItemRendererAtColumn(index+1, templateDetailsGrid.columnCount-colIndex);
        if(nextFocusComponent)
        focusManager.setFocus(ne xtFocusComponent.txtQty);
        else
        if(event.shiftKey)
        //scroll up
        if(templateDetailsG rid.verticalScrollPosition > 0)
        templateDetail sGrid.verticalScrollPosition--;
        //try to focus in the next renderer after scrolling
        nextFocusCompo nent = templateDetailsGrid.indexToItemRendererAtColumn(index-1, templateDetailsGrid.columnCount-5);
        if(nextFocusCo mponent)
        focusMana ger.setFocus(nextFocusComponent.txtQty);
        else
        //scroll down
        if(templateDetailsG rid.verticalScrollPosition < templateDetailsGrid.maxVerticalScrollPosition)
        templateDetail sGrid.verticalScrollPosition++;
        nextFocusCompo nent = templateDetailsGrid.indexToItemRendererAtColumn(index+1, templateDetailsGrid.columnCount-5);
        </fx:Script>
        <local:CustomNumericStepper id="txtQty" width="70" value="{data.Quantity}" preventKeyDown="true"
        verticalCenter="0" horizontalCenter="0" textAlign="left" tabIndex="1" stepSize="1" maximum="999999" maxChars="6"
        change="outerDocument.txtQty_changeHandler(txtQty.textDisplay.text, data.ID, data.Quantity)"
        keyFocusChange="txtQty_keyFocusChangeHandler(event)"/>
        </mx:HBox>
        </fx:Component>
        </mx:itemRenderer>
                                                        </mx:DataGridColumn>
      When I'm typing in the MXML, FlashBuilder recognize the custom attribute as it is listed in the intellisense, however that attribute is never set up. I tried looking into the value in events such as childrenCreated, commitProperties, etc but it's always false.
      Am I missing something here ? Please help !! Thanks.. Sorry for the long post
