1 Reply Latest reply on Apr 7, 2008 11:06 AM by creelove
    Apostrophe help
      I have a cold fusion program that exports/imports records in an Oracle DB with XML. It's converting from CF to XML in the import, then back to CF in the export. My problem is that when it is converted back to CF, the apostrophe's turn into double quotes. I've narrowed it down to being the import process because the actual XML file is correct, so I know it doesn't change it when going to XML. Has anyone every encountered this problem?? I know code would be helpful to better explain, but unless I type it all out, I can't get it on here. Thanks - any help would be appreciated!
