In the past I was able to add a Google map via Google api key. I'm having an issue finding this. Any suggestions? The goal is to add the code to my website for those that are looking for a store location from the database of stores on my website. Thanks in advance.
Are you a Kyuco member? I have used this http://kiyuco.com/tutorials/map-locations-using-the-built-in-web-app-google-maps-module it worked well for me.
Yes. I'd recently joined. At the time of my question, I wasn't a member yet. But I did looked at the tutorial. The issue was getting the API key. Unless I read it wrong on Google, things appeared to have changed on how to get access to it.
Hi there,
Yes, Google has changed things and you now don't need an API key. The good old boys at Kiyuco have a later Web App Google Map tutorial here http://kiyuco.com/tutorials/update-maps-to-google-map-api-v3 which explains how to set it up.
Hope that helps
Steve
Thank you. I'll check this out.
