5 Replies Latest reply on May 4, 2012 8:32 AM by [Jongware]
    Character Styles are lost???
    Selva_TRM Level 1
      Hi all,
      I have now experienced with all the character styles are lost when I apply paragraph style using "appliedParagraphStyle".
      var myText = myTextFrame.parentStory.paragraphs.item(1);
      myText.appliedParagraphStyle = myDocument.paragraphStyleGroups.item("Text").paragraphStyles.item("FC");
      any idea?
      Selva
        • 1. Re: Character Styles are lost???
          TᴀW Adobe Community Professional & MVP
          If you use the applyParagraphStyle method of a text object instead of
          changing its appliedParagraphStyle property, you get the option of
          choosing whether to clear local overrides. So try:
          myText.applyParagraphStyle(myParaStyle, false);
          HTH,
          Ariel
          • 2. Re: Character Styles are lost???
            Selva_TRM Level 1
            Sorry, its not working.
            Selva
            • 3. Re: Character Styles are lost???
              csm_phil Level 4
              Hi Selva,
              The Ariel solution its working fine, please find the below snapshot & js code.
              Selva
              var myTextFrame = myDoc.textFrames[0];
              //var myParaStyle = myDoc.paragraphStyles.item("1");
              var myParaStyle = myDoc.paragraphStyleGroups.item("Text").paragraphStyles.item("FC");
              thx
              csm_phil
              • 4. Re: Character Styles are lost???
                Selva_TRM Level 1
                Thanks phil.
                Actually i gave  piece of coding. I think you got idea to see my full coding. My goal is Import images using script. So first i collect the figure captions into a text box in a  document, then run my script. it import the images with caption in a new page. all are work corretly but the character sytles are missing.Below is my code.
                var myDocument = app.activeDocument;
                var a = Folder.selectDialog ("Choose the Folder");
                var b = a.getFiles("*.*");
                myDocument.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
                myDocument.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
                var top = 36;
                var left = 36;
                var bot = 144;
                var right = 144;
                for (var i = 0; i <= b.length-1; i++){
                    var inddFileName = b[i].name;
                    var myTextFrame = myDocument.pages.add().textFrames.add(myDocument.layers.item("ArtTables"), {geometricBounds:[top, left, bot, right]});
                    var img = myTextFrame.parentStory.insertionPoints.item(-1).place(File(b[i]));
                    myTextFrame.appliedObjectStyle = myDocument.objectStyles.item("ArtPortrait");
                    var myTextFrame1 = myDocument.pages.item(0).textFrames.item(0).parentStory.paragraphs.item(i);
                    myTextFrame.parentStory.insertionPoints.item(-1).contents = "\r"+myTextFrame1.contents;
                //    myText.appliedParagraphStyle = myDocument.paragraphStyleGroups.item("Text").paragraphStyles.item("FC");
                //    myText.applyParagraphStyle(myDocument.paragraphStyleGroups.item("Text").paragraphStyles.i tem("FC"), true);
                       var myParaStyle = myDocument.paragraphStyleGroups.item("Text").paragraphStyles.item("FC");
                      myTextFrame.fit(FitOptions.frameToContent);
                Selva
                • 5. Re: Character Styles are lost???
                  There is nothing left to be preserved, so that's why the 'preserve overrides' trick doesn't work for you:
                  BAM! All your formatting is gone.
                  See, for instance, this recent thread for more on this: replacing text that maintains styling issue
