1 Reply Latest reply on May 4, 2012 8:28 AM by abeall
    Distance between two objects
    Yuri Câmara Level 1
      Hi folks,
      Who knows how I can discover the distance between two selected objects without using neither guides nor grids?
      Thanks.
        • 1. Re: Distance between two objects
          abeall Level 3
          How do imagine this would working without using guides or grids? The way I normally do it is:
          1. Drag out a guide to point A
          2. Drag out a guide to point B
          3. Hold shift and put the mouse cursoe between the two -- it shows you the distance
          You could also use the measuring tool (click and hold the rectangle tool in the tool pallette.)
          Or even just draw a rectangle and look at the width in the property panel. That's a fast and easy method I use sometimes.
          Aaron Beall
          http://fireworks.abeall.com
