1 Reply Latest reply on May 4, 2012 10:37 AM by Jim_Simon
    Play issue with Mercury GPU
    jordanedit Level 1
      Premiere 5.5 chugging with Mercury GPU on. This started when adding Kona LHe+ In Out card.
      It may be I just don't have the computer power.
      HP xw8600
      Nvidia Quadro 4800
      8 gigs ram
      When playing sequence 720p with P2 footage and Dynamic Link After Effects compositions and a yellow reference line the system chugs and shows down. I thought the system would analyze and request a render. If I turn the Mercury engine to software I get red reference lines, after rendering sequence plays well.
        • 1. Re: Play issue with Mercury GPU
          Jim_Simon Level 8
          Hardware acceleration will keep your Dynamically Linked comps yellow, even though they may be very difficult to play.  This is normal.  If you need smooth playback of comps inside of PP, you'll have to render the sequence they're in using the "Render Effects in Work Area" command under the Sequence menu.
